Question about Samsung ML 2010 Laser Printer
How do you add toner in Samsung ML2010 printer w orig cartridge?
The label on the orig cartridge reads:
ML-2010 Series (E)
I have a bottle of an ordinary toner refill kit that came with a fuse.
How do I add the toner from the bottle? Though the cartridge looks like a disposable cartridge, I was told it could be done (toner can be added).
Thank you. Would appreciate any and all tips to do it.
ck choi
Posted by ckchoi_719 on
Roshan Rijal
    Sergeant:
  • 361 Answers
All samsung cartage can be refill.we use on it non magnatic dust. whi is define in ur purchase box. there is cap in cartage. from we can putdust. if ur printer shown cartage empty u shold reset it by fuse/cheap .
Posted on Jun 12, 2009
Samsung ML2010 won't feed feed paper
Rollers can wear out and lose traction. You can get spraycans of "rubber rejuvenator". Or it may be that the roller is slightly out of position somehow.
As for toner, some printers provide "feedback" to the computer of how much toner is left and you would find this in the Print System Preference "Options & Supplies".
If it doesn't, then the printer may display a "Low toner" warning, but these are usually just based on page count, rather than actual levels.
Realistically, you sometimes can't tell until the toner starts going grey and streaking. It's always a good idea to make a note of the page count on the printer at the start of each new cartridge, to see how many sheets your usage gets per cart.
Try to also consult the manual here: Samsung ML 2010 Manual
Aug 18, 2014 | Samsung ML 2010 Laser Printer
My mono laser printer samsung ml2010 is not working after installing window 7. pl. solve the problem.
Try if you want, manually assign a port to your printer. Please follow this steps.
1 Start>Control Panel>Devices and Printers 2 R Click on the ML 2010 icon
3 Select Printer Properties
4 Select Samsung ML-2010 Series
will see new window open
5 Click on the Ports Tab
6 Assign the right USB port
7 Click OK
Go back to Devices and Printers
8 Again Right Click on the ML 2010 icon and Set it as default printer
Jan 05, 2011 | Office Equipment & Supplies
My samsung ML2010 printer has Error button flashing green
your printer is not inisilize properly. it is a logic card problem.so pls you can repaired it from printer vendor.
Sep 02, 2009 | Samsung ML 2010 Laser Printer
Samsung ML2010 Printer does not receive the Paper
Make sure you have put enough paper in paper tray. Printer will not pull paper if not enough. (more than 10 sheets) hope it works. : )
Aug 10, 2009 | Samsung ML 2010 Laser Printer
Samsung ML2010 printing blank pages after toner replaced
Reputable or not, every once in a while you get a bad one (even originals). It's obviously defective. Return for a replacement
May 19, 2009 | Samsung ML 2010 Laser Printer
I have put new toner, switch printer on and it shawing arror on line. Could you tell me please what the problem is? Thank yoou.
Is the printer actually the "ML2010"?
Was it asking for toner and functioning properly prior to replacement?
Is the cartridge remanufactured? It could be defective.
I would try another one, especially if it was 'ok' before changing.
Mar 20, 2009 | Samsung ML 2010 Laser Printer
Paper jam Samsung ML2010 printer
refer to user manual from samsung web. Else mail your email address
May 30, 2008 | Samsung ML 2010 Laser Printer
Samsung ml2010 has faint printing
There could be 2 problems. 1. The "Toner Save" option is turned on. You could disable this by clicking on the toner save button or disabling it in the printer drivers. 2. Trying shaking the Toner cartridge. (This sounds crude but believe me it has worked many times).
Dec 20, 2007 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
350 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
