Question about Home
Not taking temp
Only purchased 5 months ago, used a handlefull of times its comes up with a reading saying "HI" only and no actaul temp changed batteries still not working?
Posted by Melissa on
Christian Krentz
  • 694 Answers
Go get a new one and return that one problem solved it goes back to the manufacturer anyway
Posted on Mar 02, 2014
Wincraft desk clock says 84 degrees but that's not correct
Sometimes it does take time for things to stabilize. I have had weather instruments take up to a day to get right. Unfortunately, just because something is new does not guarantee it is working perfectly. That's why most things come with a guarantee.
Dec 02, 2017 | Heating & Cooling
I have a 2002 BMW X5. My heat does not come on. When I start the vehicle, the blower comes on, but no heat comes out. I have tried the thermostat up as high as 80 and still nothing. The heat function is...
If there is wetness on pass sidefront , very well could be heater core issues. Start with replacing thermostat much, much cheaper. However dampness on passenger side is not good. best of luck
Feb 16, 2014 | 2003 BMW 5 Series
I have a samsung HLR6156WX. Bought it new 5 yrs ago gets very very little use (guest area). Turned it off and now it wont come back on. Ive read different post about slappint the left side after leaving it...
amount of use does not counter the fact the tv was 5 years old. a blub not used for 5 years can still burn out just like any other bulb. the only thing you can do is get it replaced.
May 02, 2011 | Samsung Televison & Video
Kenmore Gas Stove, Model No. 790.72404013, oven signals it has preheated to 350 degrees in 7 minutes but it is nowhere near 350 degrees when it does this. Seems to take approximately 20 minutes to reach...
Sorry to read about your problem, I hope this helps you out.
ok it seems you have a offset issue, you need to purchase a oven temp gauge. See what the unit read's, lets say you set the oven for 350, does it read 320 or 380. 20 min for 350 is little on the long side, you may have a gas pressure issue.
I would get a 2nd opinion on this matter. and no, they are not all like that.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Kenmore Kitchen Ranges
About six months ago, my GE XL44 gas range (purchased Dec 2002) started showing signs that it's not maintaining the oven temp I set. I tried running the self-clean cycle, but that didn't change anything....
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I'm sorry if I sound frustrated but I am - I purchased a Garmin system 2 yrs ago and after 14 months it went on the blink. After 2 months of trying to get help I purchased another one in July this year -...
I would call garmin and see what they will do about it. Good luck thou, It will be hard to prove that the temperature change caused that. It regularly gets down to -20 or -25C here and I don't ever have a problem with any of the gps, lcd screens that I have had, other than being a bit slow.
Oct 29, 2009 | Garmin nuvi 255W GPS Receiver
Samsung htz510 wont read dvd or cd? It just says loading for ever and then says error???
I have the same issue, along with a Rear Check issue at power up, and the fan stopped working about a month ago, so three strikes and your out, I would not recommend this product due to the quality. My Oniko was purchased years ago and is still going strong, I moved to an apartment and wanted the wireless ease with the back speakers, never again with this brand. My Samsung LCD is acting up now too, it is only 15 months old, and won't power up right away takes like 5 attempts, unreal
Aug 13, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Cd rom of PS3 can't read disk
a ps3 is supplied with a one year warranty as standard with sony. speak to them direct.
Dec 17, 2007 | Sony Playstation 3 (PS3) Console
Home Logo
255 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
