SOURCE: how do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
ALARM AND HOURLY CHIME
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
SOURCE: Watch stops
i have no solution but i cant even get mine open, how do i open this? [email protected]
SOURCE: Replacement watch batteries
When you buy your watch the manufacture puts in a battery that is made to last 5 years so that the watch can sit on the shelf and not need the battery changed before you have even bought it. Batteries you buy from a store or a watchrepair usually last about 1.5 years. Sometimes you can find a watchmaker who carries the five year batteries, but most people don't want to pay the $25-$30 to have it installed so most places won't carry them for rear they will never sell.I would also tell you NOT to buy your batteries from a grocery store or a Wallgreens type place because those batteries could have been sitting there for months, or even over a year. If you go to a watch repair they go through so many batteries that almost evey time you are getting a fresh battery.
SOURCE: casio watch problem
Appreciate the direct "Ask Me".
Offhand, I would say yes to the battery replacement. Though watches are not within my immediate field. This would be based on your post "2-5 minutes behind". As to the "lost signal" after a reset, may I request that you post back the specific model number pls.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
