Question about Miscellaneous
How to change language on bluedio I4 headset - Miscellaneous
sntphp
    New Friend:
Press the Call Button and Vol(-) at the same time to convert English to Chinese.
Posted on Jul 29, 2014
Matthew Cables
    New Friend:
Plug In the BlueDio bluetooth earphone first in your ears.
Step 1: While the device is OFF, press and hold the Power button until the blue light is stable (not blinking, but constant blue)
Step 2: Press and hold the Volume low (-) key and without releasing that button, press Power key, then it will prompt different language like Espanol (spanish), English and so on.
Step 3: Once it prompts the English language, release both the button and then 'press n hold' the Power key to shut it down.
* This time it will prompt you in English, 'Power Off' and going forward will remain English.*
- Cables
Posted on May 22, 2017
  • Iqbal Shaikh
    Iqbal Shaikh Mar 14, 2018
    sir. hindi me batao na
Andre Molenda
    New Friend:
You must hold the Volume Down Key and press one time the call or Power Off Button to change the Language
Posted on Apr 11, 2016
  • 3 more comments
  • Moses Kumar
    Moses Kumar May 02, 2016
    veer nice friend
  • Niclas Laggerbauer May 21, 2016
    Tried it and it worked instantly. Thank You.
  • Jebamani Dec 26, 2017
    super thanks
  • Anonymous Jun 07, 2018
    Awesome info thanks
  • Jeffrey Anderson
    Jeffrey Anderson Jul 08, 2019
    That did the trick....
Abhishek D'silva
    New Friend:
Press and hold the power button until it powers on and dot leave until u hear another beep,
now just press power on and vol - together and three sucessive beeps means u have changed your language
Happy listening to you..
Posted on Jun 28, 2017
  • Iqbal Shaikh
    bhai. hinfi me batao na
  • Abhishek D'silva
    Abhishek D'silva Mar 14, 2018
    bada wala gol button dabao aur dabake rakho...
    jab tak beep avaaj nahi ati
    abhi khali volume - ka button dabao
    teen baar beep ayega, samajh lo apka language change ho gaya..
    Cheers...
victorfash
    New Friend:
I tried using the call button and the volume button to convert from Chinese to English but it still isn't working. Please what do I do?
Posted on Oct 11, 2015
  • 2 more comments
  • amarnath mr
    amarnath mr Nov 16, 2015
    Just press both the vol(-) and the call button ones to geather not to be kept pressed just press both the buttons once at the same time
  • Raramai Mandinga
    Raramai Mandinga Jan 25, 2016
    I pressed the call button for 15 seconds first. Then I pressed the (next + volume down) buttons simultaneously. It worked
  • Rajadurai Sam
    Rajadurai Sam Feb 27, 2016
    i tried both the above step its doesnt work any other idea ?
  • Anonymous Mar 22, 2017
    To change the language of these headphones, simply press and hold the volume down button, then press the power button to toggle through the available languages
bazzy loa
    New Friend:
Posted on Mar 22, 2017
Shaikh Riyaz Ahmed
    New Friend:
Press the Call button till blue light glow continuously the Press Vol(-) button and call to change language
Posted on Jan 08, 2017
Bluedio bluetooth service center in Bangalore
I purchased Bluedio I4 bluetooth headset a month ago and as I was out of town for a month the device was received by my mom and it was not unpacked. I unboxed it today and after putting to charge for 4 hrs I took of the charger and tried to turn on the bluetooth by pressing the call button but it does not turn on. However it works only when it is plugged to the charger? What could be the problem? Have I screwed the device or is it a device problem?
Regards,
Sajith.
mail - [email protected]
Feb 21, 2015 | Audio Players & Recorders
How can i turn on my bluedio E9
very simple....jst hold the on button(continuesly) then search for de device.....when it shows up press conect den press 0000 for de pair code...thats all and any thing u see jst press yes!!!.
Feb 09, 2013 | BestOfferBuy Bluedio H9 Bluetooth Micro...
How do i pair my Nokia 500 phone with my Bluedio bluetooth device?
Your device should recognize the connection automatically when you're in proximity or nearness.
Aug 05, 2012 | MOBILESW Bluedio S9 Stereo Bluetooth A2DP...
Need drivers for bluedio av890 bluetooth headset, for windows 7 64 bits.
http://www.driveridentifier.com/scan/download_file.php?url=http%3A%2F%2Fdlcdnet.asus.com%2Fpub%2FASUS%2Fnb%2FDriversForWin8%2FBluetooth%2FBluetooth_Intel_Win7_32_VER17013120414.zip&hardware_id=BTHENUM\{00001108-0000-1000-8000-00805F9B34FB}&driver_inf_file_id=1799578&scanid=E771FAED91C24621AD587F4DAF8C8783
cheers :)
Aug 03, 2012 | Apple Bluedio AV890 Bluetooth Stereo A2DP...
Bluedio av890 is not detected in phones with bluetooth compatibility... it is getting detected only from the phone i have paired it with..With other phones it is not getting detected. what should i do to...
It is very simple yaa. Instructions are given in the user manual itself.
Switch off the Head set first. Press and hold the On-Off/call/answer key for few long seconds. First the blue light on with blinking. Don't release the switch, hold it further. Then the blue light stops blinking and shows a steady/stable/permanent glow. Now try from your mobile phone with blue tooth set to on. Search for items. On getting the indication of AV890s presence press "connect" switch. Password or Code to connect is "0000" (four times zero).
Now AV890 IS CONNECTED TO YOUR CELL PHONE. O.K.
MUTHUPETCHI V- MADURAI ([email protected])
May 02, 2010 | GE ON-SHLDR BLUTOOTH HDSET Wireless...
How to reset bluedio av890
very simple...hold the call button and the play/pause button while startin the unit up...the led will blink blue thrice and will continuously stay on confirming the reset mode...u can now view the headset as AV890 on ur phone or pc....the code is 0000...confirm it and the connection is authenticated...done...q.e.d
Apr 13, 2010 | GE ON-SHLDR BLUTOOTH HDSET Wireless...
Miscellaneous Logo
13,464 people viewed this question
Top Miscellaneous Experts
Buddy Clements
Buddy Clements
Level 1 Expert
James Cagle
James Cagle
Charles Blake
Charles Blake
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
