Question about Legacy LDN7U Car Video Player
Choke box 12v wire and ground wire came out of wire harness
The wire that powers the radio have came out of the radio including the ground wire
Posted by Donte Dansby on
I have an 89 camaro rs, I am getting power to the red power wire on my radio, but when I turn on the car I get no response and cd radio will not work. Any ideas?
there are two power wires to most radios. usually red and yellow. the red wire provides 12v when the key is turned on and yellow provides a constant 12v. both must have power to turn the radio on. there will be two fuses for the radio also so make sure both fuses are good. the only other thing that will keep the radio from coming on is the ground wire "usually black" that has to be connected to the ground in the factory harness or you can just connect it to any bare metal behind the dash
Oct 20, 2012 | Cars & Trucks
Which wires go to what in the radio
ITEM - WIRE COLOR - POLARITY - WIRE LOCATION
12V - red - POSITIVE - ignition harness
STARTER - white - POSITIVE - ignition harness
IGNITION - red - POSITIVE - ignition harness
ACCESSORY - red - POSITIVE - ignition harness
SECOND ACCESSORY - yellow - POSITIVE - ignition harness
BRAKE WIRE - white - POSITIVE - brake pedal switch
RADIO 12V - red - POSITIVE - radio
RADIO GROUND - black - NEGATIVE - radio
RADIO SWITCH - yellow - POSITIVE - radio
RADIO ILLUMINATE - pink - POSITIVE - radio
POWER ANTENNA - gray/orange - POSITIVE - radio
LF SPEAKER - white - brown - radio
RF SPEAKER - green - orange - radio
LR SPEAKER - yellow - black - radio
RR SPEAKER - orange - blue - radio
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 02, 2011 | Hyundai Motor 2003 Elantra
I am installing a new cd player in my 2006 dodge ram single cab truck, i have made the mistake of the cutting the stock wiring harness plug. Now i need to know what color codes are on these wires so i can...
Hello my name is Israel. I have added the following informaiton to help you out. Good Luck.
Radio 12v gray/red + radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink/yellow + radio harness
Radio Illumination orange/tan (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- dk. grn/yel - dk. grn/lt. blue +,- radio harness or amplifier
Notes: The amplifier is behind the glove box.
RF Speaker +/- gray/yellow - gray/lt. blue +,- radio harness or amplifier
LR Speaker +/- gray/lt. grn - gray/dk. grn +,- radio harness or amplifier
RR Speaker +/- dk. grn/lt. grn - dk. grn/gray +,- radio harness or amplifier
Feb 21, 2011 | 2006 Dodge Ram 1500
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
I need a radio wiring diagram for a 1995 jeep wrangler
Answer
Radio 12v
pink
radio harness
Radio Ground black - radio harness
Radio Ignition red + radio harness
Radio Illumination orange (dimmer) + radio harness
Power Antenna N/A
LF Speaker +/- dk. green - brown/red +,- radio harness
RF Speaker +/- purple - dk. blue/red +,- radio harness
LR Speaker +/- brown/yellow - brown/lt. blue +,- radio harness
RR Speaker +/- dk blue/orange - dk blue/white +,- radio harness
Jul 15, 2010 | 1995 Jeep Wrangler
I need an elecrical wiring routing diagram for a
Radio 12v, blue/red, +, radio harness
Radio Ground, black/yellow, -, radio harness
Radio Ignition, orange, +, radio harness
Radio Illumination, lt. green/red, +, radio harness
Factory Amp Turn-on, blue/black, +, radio harness
Power Antenna, N/A,,,
LF Speaker +/-, red - white," +,-", radio harness or amp
RF Speaker +/-, blue - yellow," +,-", radio harness or amp
LR Speaker +/-, purple - pink," +,-", radio harness or amp
RR Speaker +/-, white/blue - black/blue," +,-", radio harness or amp thats for non bose 04
Sep 21, 2009 | House Brand Car Audio & Video
Toyota tacoma 2007 stereo wiring Colors for the following wires: Power-ignition Ground
Radio 12v blue/yellow + radio harness
Radio Ground brown - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Power Antenna N/A
LF Speaker +/- pink - purple +,- radio harness or amplifier
RF Speaker +/- lt. green - blue +,- radio harness or amplifier
LR Speaker +/- black - yellow +,- radio harness or amplifier
RR Speaker +/- red - white +,- radio harness or amplifier
Notes: If equipped, the amplifier is on the passenger side rear cabin wall.
Sep 13, 2009 | 2007 Toyota Tacoma
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Radio wiring harness color codes for 2004 Jeep GC
This is for a 2002 cherokee:
RADIO 12V - red/white
RADIO SWITCH - white/red
May 16, 2009 | Cherokee Car Audio & Video
The stereo wire colors for the 2001 chevy s 10
Radio 12v  orange  +  radio harness Radio Ground  black  -  radio harness Radio Ignition  dk. green  +  radio harness Radio Illumination  brown  +  radio harness Factory Amp Turn-on  orange  +  radio harness Notes: The amplifier is behind the glove box. Power Antenna  N/A     LF Speaker +/-  tan - gray  +,-  radio harness RF Speaker +/-  lt. green - dk. green  +,-  radio harness LR Speaker +/-  brown - yellow  +,-  radio harness RR Speaker +/-  dk. blue - lt. blue  +,-  radio harness
May 02, 2009 | 2002 Chevrolet S-10
Legacy LDN7U Car Video Player Logo
43 people viewed this question
Top Legacy Car Audio & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
