Can't you use "Y" connectors to add additional devices to the existing sound out ports?
You could use a Speaker Switch. You can find an ione at: http://www.bestbuy.com/site/4-pair-stereo-speaker-selector/9746779.p;jsessionid=A65E902544159CF276BC147D7BE1F696.bbolsp-app02-185?id=1218166511087&skuId=9746779&st=categoryid$abcat0107032&cp=1&lp=1#tab=overview
SOURCE: Subwoofer not working
you have to reset the receiver, i had the same problem, works now, it's great, should be in the instruction booklet. I think it was, hold the power button while you disconnect it from the wall, not too clear but check the booklet in resetting system
SOURCE: Kenwood VR-305 receiver surround speakers will not work
make sure that all input cables are in the correct positon also make sure that any inputs you are using don't have a macrovision in them that will also kill your sound due to copyright laws and stuff but main thing check all wires coming in to receiver and if you need more inputs go to walmart and get a rca splitter basicaly its a 1 in two out connection to add more cables in the input
SOURCE: Connect a Sony SA-W3800 powered subwoofer to a kenwood receiver
Yes. It needs to know you have a subwoofer or it won't send low frequencies out to one. Then you have to calibrate its level to match the rest of your speakers. Hit the SETUP section in the manual (available at retrevo.com).
Testimonial: "Thanks for your help! Reading your post helped me work out the issues."
SOURCE: How do I connect my
The best way to do this is to connect you dish network receiver is directly to the tv. Try to use the best video type possible. HDMI is the best, next is component and lastly is composite. This will take care of the video portion. Next, connect digital audio output to the Kenwood Receiver. I dont know what type of a digital audio output your dish box has, but your kenwood receiver has both optical and coaxial inputs so you should be fine there. Once you have both audio and video wired, change the inputs on both your tv and kenwood receiver to the inputs you are connected to. You might need to set up the kenwood to tell it that your running digital audio to it in the setup menus. Hopefully this helps, let me know if you need any clarification.
Good Luck
