Each time I send a print job to print Avery labels (via avery template within word on my macbook)the printer hangs. To fix i have to delete then reinstall print driver - with no labels printing. As a test I attempted to print job on regular card paper and same thing happens. Can not locate any settings to change and find it hard to believe that I can't simply print a sheet of labels. Any suggestions for a fix?
Avery labels may be blocked on your computer so check your security settings. Other wise you may need to refresh the page, your computer or the printer. If that doesn't help you may need to double check your ink cartridges are full and correctly placed, also that the wires connecting the printer to your computer are all in properly.
SOURCE: Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
SOURCE: Problem printing business cards
in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
SOURCE: Printing on templates
This is normally set through the page margins within the software you are using not the actual printer settings. MS Word has templates for various Avery labels, but I've found after loading the template you have to fine tune the margins for your printer. Use plain paper to print test pages and hold them over your card stock to check alignment.
SOURCE: c6180 will not print labels as set out in the
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
SOURCE: My hp officejet J4680c printer and my hp pcs 1315
follo0w the link to avey for further help
http://www.avery.com/avery/en_us/Help-Center/Formatting-and-Printing-Tips/_/Ns=Rank
