Question about Kenwood KAC-9152D Car Audio Amplifier
What is best way to hook up two dual coil 400 watt adieobahn speakers to a 20 tis amp
To two audiobahn 12in dual coil speakers
Posted by steven on
3 Related Answers
Anonymous
  • 655 Answers
SOURCE: Have kenwood mono amp 4,2,1 ohm capabilitie. What
Hello pelikant75,
The best answer depends on your budget for the sub(s) and exactly what kind of sound you are looking to get. Your amps RMS output at 4 ohms is 200 watts and at 2 ohms, it's 400 watts. I could not find that it was 1 ohm stable.
If you are looking for the absolute best bang for your buck, I would highly recommend a pair of entry level MTX 10" subs, model 4501-04, currently priced by Crutchfield at $49.99. And if you buy a pair, they throw in a free Bass Slammer BS210S sealed enclosure. The MTX's power range is 112.5 to 225 watts each, right in there with your amps output. 2 of them in parallel give you a 2 ohm load, just right for your amps best power. And they sound great. You simply can't find a better deal for $100 bucks!
If you want a little better SQ, a pair of Rockford-Fosgate P1S410's should be considered. Again, going to Crutchfield, they currently have this one "BOGO" (buy one get one) for $99.99. You will have to provide your own box, though, no free one with these.
Finally, if you want the best SQ, and your budget allows, consider a set of Alpine SWR-1022D's for $179.99 each. These have dual 2 ohm voice coils, allowing you to series the coils and parallel the subs, resulting in a 2 ohm load to you amp just like the MTX's and RF's recommended above. You will probably want a somewhat larger enclosure for the Alpines as well as a fatter wallet. Your amp is right at the lower end for powering them, so they probably will not be as loud. But they will sound good.
One thing we haven't discussed is the box. The enclosure is just as important, perhaps even more important than the sub(s). More accurate bass is generally produced from a sealed enclosure. A ported enclosure will be louder, but at the expense of sound quality. And whether it's sealed or ported, the enclosure needs to have enough internal volume for the particular sub you are planning to use. A sealed box in the range of .75 to 1 cu/ft will be OK for any of the recommended subs. Add about 15-20% more volume for a ported box and keep in mind that the port needs to be specifically sized for the frequency for which it is tuned.
Hope this helps.
Posted on Apr 13, 2009
Anonymous
SOURCE: how should i have my
On the outputs of the amp there is:
1 2 3 4
terminals. Internally in the amp the positives (1 and 2) are connected together and negatives (3 and 4) together. So there is no difference between hooking up in any of the configurations 13, 14, 23 or 2->4. If its a matter of style, probably use the 14 set, since they're furter apart and harder to short out that way, but electrically it doesn't matter.
Posted on Mar 17, 2011
Robert Struzinski
  • 185 Answers
SOURCE: what amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono powe
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Posted on Apr 04, 2013
2helpful
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
1helpful
I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • 0helpful
    No knowledge of how to hook two subs which are the 12 alumni audiobahn sub to a performance technique 781 mono block amp operation ohms for the speakers say 3 or 12 ohms during operation can i bridge or do...
    yor subs have dual 6 ohm voice coils from the sound of it-your amp is rated at 650 watts rms at a 1ohm load. The best you can do with the equipment you have is to wire ALL the coils of your subs in parallel and that will give you a 1.5 ohm load for the amp.It should knock the hell outta them with 300 watts on each sub - good luck
    I HAVE A ZEUS ZS12 350 WATTS AND IT HAS THREE HOOK UPS ON THE BACK HOW DO i HOOK THEM UP
    This is a dual coil sub . Go to :
    www.colomar.com/Shavano/dvc_spkr_wiring.html
    There are several ways to hook up this type of sub. The web site will explain.
    What amp need to use for Kicker (2) S12L7 12in Solo Baric
    you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
    Help me with my system
    More information is required to start solving your problem. (ie. your make and model of "1500W amp", the voicecoil configuration of the kicker and Audiobahn 15's, and why you want to encorprate 2 crossovers in your system)
    Seems as If you have a system without a plan.
    Head unit?
    More info necessary to give you the best use of your components.
    1helpful
    I dont know which wires go where on the back of my sub woofer. its an audiobahn aw1251t woofer, 400 watts
    I used to have exactly the same subwoofer. It has dual voice coils which are driven independently.
    Hope the diagrams help out. Just make sure you know how many ohms your amp is.
    Wiring Option #1
    Wiring Option #2
    Kenwood KAC-9152D Car Audio Amplifier Logo
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
     Francisco Mauricio...
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
