Question about Konica Minolta Office Equipment & Supplies
P 5 error in konica milolta c450
How to solve the IDC/Registration Sensor in konica minolta bizub c450
Posted by boysxerox on
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Sir/Mam
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed.. recommended a tech do this unless you known what you are doing.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 18, 2016
4 Related Answers
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Posted on Jul 18, 2008
Anonymous
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
Anonymous
  • 61 Answers
SOURCE: Error code C-3505 Konica Minolta Bizub C6500
This is a fuser code, which needs reset by your service provider in service modes, let me
Posted on Dec 29, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: how can solve error p 5 idc sensor in konica minolta bizhub c450
P5 front IDC sensor failure.Wipe clean the surface of the transfer belt if it is dirty with a soft cloth or change the transfer belt unit is damaged.Reinstall or reconnect IDC sensor shutter or connector for every color unit and clean the sensors when vacuum cleaner after remove the all imaging units and the transfer belt unit.
Posted on Mar 25, 2014
How do i reset error c20 in bizhub konica minolta
OHP sensor malfunction had a tech check it out and or replace
Jun 04, 2016 | Konica Minolta Office Equipment & Supplies
Where is the IDC front sensor in konica minolata C450
Located under the transfer belt, which mean the belt has to be removed then must know witch accurator to depress to open the cover that protect them when the belt is not installed. One is to the rear the other is to the front. looking from thee right side of the machine
Jun 03, 2014 | Konica Minolta bizhub Office Equipment &...
How can solve error p 5 idc sensor in konica minolta bizhub c450
Mar 25, 2014 | Konica Minolta bizhub Office Equipment &...
Error p 5 konica milnolta bizhub c450
Remove the transfer belt. Then right below the fusing unit right where the edge of the transfer belt is located when normal installed right below where the edge of the belt would be. Are two sensors they are cover with the belt out and door open so you will have to GENTLE open them with your fingers and GENTLE clean them DO NOT USE AVACUUM CLEANER THE STATIC ELECTRICTY from the vacuum cleaner can destroy the sensors.
Error p5 in konica minolta c450
Mar 01, 2014 | Konica Minolta Office Equipment & Supplies
IDC sensors are located under the transfer belt on the right sid eof the machine. Belt must be removed to clean sensors. Once belt is removed sensors are located on a black plastic frame and have slideable covers that can be moved by hand to clean sensors. There are 2 sensors one machine front and one machine rear.
Mar 01, 2014 | Konica Minolta bizhub Office Equipment &...
C450 c-0204
Remove the 2nd draw and ensure no paper behind it, THEN REMOVE ALL PAPER IN THE DRAW ON THE LEFT SIDE IT IS NOT A STORAGE AREA!!!! IT is use for 11 x 17 paper, or you have a burned out motor worse case a burned out motor that took the main control board that controls the motor also.
Feb 24, 2014 | Konica Minolta Office Equipment & Supplies
C450 c-0204
Pull out the cassette and check the paper capacity not to exceed the maximium level. Clear any irregular or untidy paper if any.
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
B420 konica minolta
Check the following , Dirt of IDC sensor, Clean up the IDC sensor, if no then Printer control board abnormality Replace board
Jun 19, 2008 | Konica Minolta Office Equipment & Supplies
55 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
