Canon PowerShot S1 IS Digital Camera Logo
Question about Canon PowerShot S1 IS Digital Camera
Black scren no display
Black lcd scren
Want to know schools for a three year child
my casio digital watch model 675 DB-520 lcd display has broken and everything else was working fine,but because no scren display I want to replace my broken screen
Aug 03, 2013 • Watches
Hp modelt60m283 run black scren
Turn off your pc and connect another monitor. If the external monitor works fine then the screen cable is damaged or your laptop's LCD needs replacement.
37IN TV FLAT SCREN HAS SOUND BUT NO PICTURE WHATS WRONG
you lcd tv maybe have problem in inverter board if black screen? & maybe t-con board bad if lcd screen come on light up. maybe that could help? good luck!
2helpful
Display blank on lg cookie buttons light up and still ring when reciveing phone calls or text, but no display scren is black
It seems that the LCD is problematic. You need to get it repaired by an expert near you. OR if you are an expert and can handle it then get your LCD screen from these site:
Remember, the issue can also be the flex cable that is attached with the LCD but hard to repair so initially try to get it repair by some repairshop or get the LCD . One of the sites is given below.
mrmobileuk.com/lg-m-12.html
goodluck
My camera turns on however the screen is black it takes pictures i just have to point and shoot but i cannot see on the screen exactly what i am taking. I then have to go onto my computer and put them on...
if your screen does not display any figures , numbers or icons then the LCD screen is dead. If you look closely at the LCD scren and fine cracks or lines on it then i advise ou to take it to arepair shop for replacement.
rgds
Luwangula
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
2answers
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
The scren is black i cant see any thing
For the second problem, can you get the white writing before Windows kicks in? If so, you will have to hit F8 and start Windows in VGA mode so you can see it. Then you can adjust the graphic display. It could very well be your graphics card is displaying something out of your monitor's range.
Lcd scren not display picture
The screen is not turned off in the camera setup menu.
randell
Lcd flickers
hi
the 400d has a sensor just below the optical view finder
it detects when you face is near the view finder and turns off the lcd scren
the display button (top left) can manually turn the lcd on/off
refer page 101 of the manual to modify this setting
D
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Marvin
Marvin
Are you a Canon Camera Expert? Answer questions, earn points and help others
