Question about JVC HR-A592U S-VHS VCR
Programming onn A12Av058
The instruction manual does not explain how to choose the "shifted" devices when programming.. it wont let you press shift to get VCR .. soo..
Www philips com guarantee
You have to do a code search as explained in the instructions for your Philips universal remote control. Your Panasonic VCR will not respond unless the correct code is found and entered.
Jan 06, 2014 | Computers & Internet
Tip
DISH Solo DVR VIP612 Program TV VCR Remote Code
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | DISH Network ViP 612
No channels listed on tv after reset was done
The entire memory was wiped off as you had reset the TV . Soo all you need is to open the menu and choose the settings, choose the auto programming and scan.
Once the programs listed on your cable or network has memorised you can shift the channels to the required selected program numbers to your desire.
Sep 06, 2011 | Westinghouse Televison & Video
My 722 wont program to operate my BOSE GS Series II.
russ063
761 47% thumbs_up.gif thumbs_down.gif 780 761 47% thumbs_up.gif thumbs_down.gif 780 761 47% thumbs_up.gif thumbs_down.gif 780
I have provided the codes and instructions on how to program your DISH remote to your Bose receiver. I hope this helps.
Remote codes:761 and 780
Instructions on programming:
Address To Other Equipment Using Code
  • Remotes: Multiple Mode Buttons (TV,VCR, AUX)
    1. Press and hold the desired Mode button until all mode button backlights come on, then release.
    2. Use the number buttons to enter the device code corresponding to the equipment. AUX Mode: Before entering the device code:
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Note: The light will blink off after each digit is entered and then return to a steady light.
    3. Press the POUND (#) button.
      If the code entered is valid for the remote, the mode light flashes three times.
Ray Calo
DISH Network
Mar 13, 2011 | Directv (R10) DTV Receiver / 70-Hours...
SIR, I wish to known MS Office 2007 advance functining & sortcuts
Function keysTo do this Press
Get Help or visit Microsoft Office Online. F1
Move text or graphics. F2
Repeat the last action. F4
Choose the Go To command (Home tab). F5
Go to the next pane or frame. F6
Choose the Spelling command (Review tab). F7
Extend a selection. F8
Update the selected fields. F9
Show KeyTips. F10
Go to the next field. F11
Choose the Save As command (Microsoft Office Button ). F12
SHIFT+Function keyTo do this Press
Start context-sensitive Help or reveal formatting. SHIFT+F1
Copy text. SHIFT+F2
Change the case of letters. SHIFT+F3
Repeat a Find or Go To action. SHIFT+F4
Move to the last change. SHIFT+F5
Go to the previous pane or frame (after pressing F6). SHIFT+F6
Choose the Thesaurus command (Review tab, Proofing group). SHIFT+F7
Shrink a selection. SHIFT+F8
Switch between a field code and its result. SHIFT+F9
Display a shortcut menu. SHIFT+F10
Go to the previous field. SHIFT+F11
Choose the Save command (Microsoft Office Button ). SHIFT+F12
CTRL+Function keyTo do this Press
Choose the Print Preview command (Microsoft Office Button ). CTRL+F2
Cut to the Spike. CTRL+F3
Close the window. CTRL+F4
Go to the next window. CTRL+F6
Insert an empty field. CTRL+F9
Maximize the document window. CTRL+F10
Lock a field. CTRL+F11
Choose the Open command (Microsoft Office Button ). CTRL+F12
CTRL+SHIFT+Function keyTo do this Press
Insert the contents of the Spike. CTRL+SHIFT+F3
Edit a bookmark. CTRL+SHIFT+F5
Go to the previous window. CTRL+SHIFT+F6
Update linked information in an Office Word 2007 source document. CTRL+SHIFT+F7
Extend a selection or block. CTRL+SHIFT+F8, and then press an arrow key
Unlink a field. CTRL+SHIFT+F9
Unlock a field. CTRL+SHIFT+F11
Choose the Print command (Microsoft Office Button ). CTRL+SHIFT+F12
ALT+Function keyTo do this Press
Go to the next field. ALT+F1
Create a new Building Block. ALT+F3
Exit Office Word 2007. ALT+F4
Restore the program window size. ALT+F5
Move from an open dialog box back to the document, for dialog boxes such as Find and Replace that support this behavior. ALT+F6
Find the next misspelling or grammatical error. ALT+F7
Run a macro. ALT+F8
Switch between all field codes and their results. ALT+F9
Maximize the program window. ALT+F10
Display Microsoft Visual Basic code. ALT+F11
ALT+SHIFT+Function keyTo do this Press
Go to the previous field. ALT+SHIFT+F1
Choose the Save command (Microsoft Office Button ). ALT+SHIFT+F2
Display the Research task pane. ALT+SHIFT+F7
Run GOTOBUTTON or MACROBUTTON from the field that displays the field results. ALT+SHIFT+F9
Display a menu or message for a smart tag. ALT+SHIFT+F10
CTRL+ALT+Function keyTo do this Press
Display Microsoft System Information. CTRL+ALT+F1
Choose the Open command (Microsoft Office Button ). CTRL+ALT+F2
Jan 05, 2011 | Microsoft Office Computers & Internet
The car wont come out of park
The problem is with the shift interlock switch...the device which prevents the transmission from being shifted out of park without the brake pedal pressed. The switch is usually located somewhere under dash near steering column on column shift models and under the console on floor shift models. Have it replaced.
Jun 11, 2010 | 1995 Oldsmobile Eighty Eight
Using the select shift in my 2009 sonata
The purpose of shift tronic is to give the driver the option of driving like a manual where you command the shift, or auto for easy driving (little effort). It is not specifically used just to down shift or upshift. When you are in 5th gear, thats it, it will do in it normal mode or sport shift.
May 17, 2009 | 2009 Hyundai Sonata
Ineed a manual for a Fisher VCR
This may help.
Hold down tv power enter the 2 digit code using number buttons 0-9 then release tv power button
Admiral 05, 10 13 - Emerson 17 - Fisher 03 – GE 07 – Gold Star 01 – Hitachi 02 – JVC 15 – Magnavox 08 – Matsushita 12, 18 - Mitsubishi 14 – Panasonic 12, 18 - Quasar 12, 18 – RCA 06 – Samsung 16 – Sanyo 03 – Sharp 00, 13 - Sony 11 – Technolace 05 – Toshiba 04 – Zenith 09,10
And now the impossible clock setting. Turn unit on press clock while holding down the shift button. Press fast forward or rewind to change hours, then press adjust while holding down shift button to select the minutes again use the fast forward or rewind arrows to change minutes then again the adjust and shift combo to start clock.
Good luck Kevin
Fishers help line is 1-800-421-5013
Jan 29, 2008 | Televison & Video
I have codes but no instructions
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Dec 01, 2007 | One For All URC-3021 Remote Control
Remote control
I used a GE Universal remote. The package has number 24921 and the instruction manual says it's a RM24912. Anyway, this model will control pretty much all aspects of this tv combo assuming we are talking about the KLH KDT133UY tv/dvd.
What you need to do is program the tv button on the remote to code 0029 which is a KONKA code. The real maker of KLH electronics. Then set the dvd/vcr button to code 0905. Now in order to access the tv menu, press the tv button then press the shift button which is the setup button. Then press the INFO button for menu. SHIFT, MENU, OK, and EXIT are printed with a black backgroung on the remote. Hince you need to press shift.
Took a while to figure it out, but here you go. Good Luck!
Nov 20, 2007 | KLH KDT133UY 13 in. TV/DVD Combo
JVC HR-A592U S-VHS VCR Logo
42 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
