How do I connect effects rack (Lexicon) to Tascam 2488 MK 2?
I've got a Lexicon too and I love the thing.
To use the Lexicon as a 'send effect' (which is what it is) you'll need to connect the effect sends from the back of the 2488 to the inputs on your Lexicon. Then connect the outputs from the Lexicon into two inputs on the 2488. Then assign those inputs to tracks.
You've got to select the previously recorded track(s) where you want to add reverb or other effects (by pressing the select key) and then press the 'send' key to get into the 'send effect' screen. Here you can adjust the amount of signal is sent from that channel to either of the effect sends (typically you might want to send one track of a stereo set of tracks out eff 1 and send the other track out eff 2).
Pre, post or off will determine whether the fader affects the signal being sent or not and the loop setting on the top of this screen is for the internal effects.
Once you've got this set up the way you want you just arm the tracks where the Lexicon output is coming into the 2488 for recording, mute whatever you don't want to hear and you can bounce record the raw signal through the Lexicon and record (print) the effected signal on the tracks you've armed.
Hope this helps.
bd.
