Question about LG 37LG30 37 in. LCD HDTV
Menu pops up - LG 37LG30 37 in. LCD HDTV
How do you disable a pop blocker
Pop-ups are web pages that automatically open when clicking on a weblink; they may or may not be related to the site you are attempting to view.
Most often pop-ups are unwanted advertisements and other forms of spam, which is the reason pop-up blockers exist: to keep unwanted images and sites from interfering with normal Internet browsing.
Sometimes pop-up blockers will block sites and pages that you may want to view, in which case you may want to disable your pop-up blocker.
Create the Menu tab.
Right click in the top section on your homepage select the Menu option this will add File Edit View Tools and Help to the top of your homepage
Click the Tools menu.
Scroll down to "Pop-up blocker."
Select, "Turn off popup blocker."
Disable Pop-up Blocking in Firefox
Select the Tools, menu and click "Options."
Click the Content tab.
Uncheck the box labeled "Block pop-up windows," then click "OK."
Disable Stand Alone Pop-up Blockers
Press "Control," "Alt" and "Delete" simultaneously to bring up the Task Manager.
Find your pop-up blocker program and highlight it, under the Processes tab.
Select "End process."
Sep 11, 2013 | Computers & Internet
Main menu on the lower right hand side keeps popping up
Sounds like your menu button on the monitor is stuck in the pushed in position. See if that is the problem and use a needle, q-tip with alcohol to pop it back out.
Jan 27, 2013 | Gateway FPD1975W 19" LCD Monitor
ThinkCentre M90z lock menu problem
What menu? What does the pop up say? Just " lock menu"?
Dec 19, 2012 | Lenovo TopSeller ThinkCentre M90z AIO Core...
Menu from Projector keeps popping up. it will clear away when we click MENU button but then within 5 seconds, it will pop up again. we are using ACER XD1150 DLP PROJECTOR. would appreciate any...
hi,
Check is the remote transmits signals for menu at any time.
to check this after clearing the menu remove the battery of the remote. if the menu didn't po pup again , the remote need cleaning .
If the menu pop up again then, you have to check the menu button (push button) on your projector.
ok
Feb 21, 2011 | Acer XD1150 DLP Projector
Menu keeps popping up
check remote faulty batteries/take them out see if it stops doing it also depress menu button on tv might be stuck
Nov 10, 2009 | Philips 42PF9630A 42 in. Plasma Television
Monitor Resolutions Menu Pop ups
Please disable this notification from settings menu of monitor. you should find it under settings or notification menu which can be accessed via switches on monitor.
Jun 14, 2009 | E-Machines eMachines Desktop PC
Menu pop up
needs sft waer update call philips
Jun 02, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Problem about "services.exe - Application Error" pop-up menu
Apparently, you computer has some unexpected software running during the startup. In order to get ride of these software, you could check your register table manualy by regedit or download this software, which will help you to find if there are any suspect software running at the startup.
files.filefront.com/sreng2zip/;8049311;/fileinfo.html
May 07, 2009 | Computers & Internet
LG 37LG30 37 in. LCD HDTV Logo
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
