Question about Digix BT-100 Portable Bluetooth Wireless Speaker with Microphone BT-100 PURPLE
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Followed operating directions, but cell phone does not recognize the BT-100.
Posted by Terry Wofford on
GregoryGatti
    New Friend:
  • 31 Answers
Try to use Crystal portable Bluetooth speakers, easy to use as well as good sound as well as Lithium-Ion battery. Bluetooth speakers and hands free kits Supertooth
Posted on Mar 20, 2015
A Lee
    New Friend:
    Problem Solver:
  • 14 Answers
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Posted on Apr 21, 2014
Bt-100 bluetooth speaker volume to low can't turn up
There are several issues that may be causing the volume to be very low.
SPEAKER VOLUME:
(1) When you press the Vol+ button on the speaker does it make a beep sound? (It should, even if it can not longer go up or lower).
(2) Be sure to continue pressing the Vol+ Button to ensure that the volume does increase.
(3) While this is rarely an issue, may want to check that the speaker is charged.
DEVICE VOLUME:
*Please note that some devices have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Ensure that Media Volume is on.
(2) Ensure that the volume is turned up on the device by using the devices Vol+ controls
MEDIA VOLUME:
*Please also note that the media being used (Youtube, Hulu, Music Player, etc.) may ALSO have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Check that the volume within the media is turned up as well.
Hope this helps! You can also contact customer service for DIgix at 1-866-770-3688 for further assistance.
Jun 30, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Is it waterproof
This device is Water RESISTANT. IPX-5. It can get wet, be splashed and fall into water. As long as it is quickly removed and too much water does not seep through the top holes the speaker will be fine. It works great in the shower where it will constantly get splashed or pool side.
Apr 20, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Digix BT-100 is not recognized by my Moto X android cell phone.
Mar 01, 2014 | Digix BT-100 Portable Bluetooth Wireless...
How do I set pairing mode
You will need to be sure that your device has BLUETOOTH. If it has bluetooth please turn on the bluetooth settings on your android device. You will now want to turn on the speaker.
Using the android device you will search for available bluetooth devices. Once you see BT-100 you will select that to PAIR. Some devices will automatically CONNECT after the devices have been paired. If not, please press BT-100 again to CONNECT. The BT-100 speaker should BEEP indicating that they have connected and the speaker is now ready to use.
Feb 04, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Wireless speaker does not turn off to end call
If the middle button is pressed and HELD for a few seconds, it should end the call. All android phones may not allow this function.
Feb 03, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Device worked the first few times I used it, then lost volume and would not increase past first dot.
Please be sure to double check that the volume for BLUETOOTH on the device (phone, tablet, etc.) is also turned up. Please note that the volume buttons on the speaker may not always control the bluetooth volume via the device.
Jan 29, 2014 | Digix BT-100 Portable Bluetooth Wireless...
It pairs for a few seconds then quits
Has the speaker been paired with another device?
Is the device (phone, tablet, etc) paired with another bluetooth device that is within range?
If the answer is YES to either of the above questions this could be what is causing the problem. Please note that most devices (phones, tablets, etc.) can only connect to ONE bluetooth device at a time. Also note that the BT-100 speaker can only connect to ONE device at a time.
Jan 18, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Digix BT-100 Portable Bluetooth Wireless Speaker says not connected when I try to pair it with my ipod.
Kathryn,
The speaker can only pair with one device. I had the same issue pairing it with my phone and then to my iPad.
You simply need to unpair it with your daughters iPod by turning off the bluetooth on that iPod, turn off then back ON the speaker and connect again to your own iPod by turning on the Bluetooth, Selecting BT100 from the list and wait for it to say CONNECTED (not paired).
Hope this helps!
Nov 07, 2013 | Digix BT-100 Portable Bluetooth Wireless...
Digix BT-100 Portable Bluetooth Wireless Speaker with Microphone BT-100 PURPLE Logo
785 people viewed this question
Top Digix Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Digix Video Camera Expert? Answer questions, earn points and help others
