Question about Amazon Kindle Fire HD
Kindle say authentication problem when trying to connect to wifi
Accidentally pressed "forget" when inputting WiFi password and now my WiFi says authentication problem and won't connect.
Posted by Barbara Hatch on
Aravind
    New Friend:
  • 15 Answers
Im sure you would have typed wrong password. please make sure you have correct password typed.
-regards
Posted on Mar 01, 2014
jackson Cooper
If you are unable to resolve the kindle won't connect to wifi error then follow these easy steps:
  1. The first step to do when a kindle faces any problem, simply restart your Kindle.
  2. If the problem is still, then restart your router.
  3. Shortened the distance with your router.
  4. Make sure to select the wifi channel from 1 to 11.
  5. If still the error not resolved then try to restore the factory setting
Hope these steps will help you the fix the kindle won't connect to wifierror
Posted on Sep 03, 2020
2 Related Answers
Martin Murray
  • 1623 Answers
SOURCE: Unable to connect my Kindle
check to see if you have a button to allow wifi access on your router, if you press that button for 2 seconds it will allow your wireless device to connect
Posted on Apr 09, 2011
TechyDrood
Justin
  • 2072 Answers
SOURCE: trying to connect kindle fire to wifi TheGriswalds has come up but do not have password help
Ask someone for the password, or if this is your router then you may need to factory reset the router and setup a new password
Posted on Dec 08, 2013
I am having a problem with connecting my Kindle Fire to the Wi-Fi. When I try to sign in, it keeps telling me authentication problem. I can't get past this answer. Please help me.
WiFi pass word incorrect or there is an issue with the WiFi router. Check password...make sure exactly the same including capitalization. Try resetting WiFi router.
Oct 08, 2016 | Amazon Kindle Fire HD
Wi-Fi states authentication problem but can't reconnect and it won't give me the chance to input password
delete/forget the wifi connection in the tablet. re do the wifi set up with the proper WEP/WPA password from the router.
Apr 18, 2015 | Proscan 7-Inch Android Internet Tablet,...
My kindle touch wont connect to my wi fi keeps saying incorrect password when i have not changed anything
Can you connect other devices to your wifi using the same password?
If so, it is the Kindle at fault.
Go to your wifi connections in Settings and remove your connection (I think it may say "forget").
Turn off your Kindle by holding down the power button for a full 30 seconds.
Restart your Kindle and connect to wifi, re-entering the password on the back of your router.
Mar 04, 2015 | Tablets & eReaders
Turning onto internet I get a white box up with retry o I have Got all the wifi settings up on the screen and underneath my TalkTalk_wifi number there is a sentence saying AUTHENTICATION PROBLEM ?
If your Kindle is not blacklisted, and the dialog box states that you have an authentication problem, then your Kindle is not connecting to your local network. Sometimes this can be caused by chip failure on the Kindle mobo, but usually it is due to an external network problem. You should try again once or twice and then if you continue to experience the problem, try to reset your local router by turning it off and on.
Feb 28, 2015 | Amazon Kindle Fire HD
Authentication problem when trying to connect Kindle to internet
go into settings and select wifi a list will pop up select and connect
Mar 01, 2014 | Amazon Kindle Fire HD
I cant get wifi connection on my kindle hd
Step 1: Remove any old connections in the Tablet by Long Press Forget Connection
Step 2: Reboot your Wireless Router
Step 3: Attempt to connect again
Step 4: If this fails, log into the Wireless router and charge the authentication mode from whatever you have now to WPA Personal and enter a Passphrase you can remember
Step 5: Connect to your Wireless using the new Passphrase
Apr 07, 2013 | Amazon Kindle Fire HD
Why does my tablet keep saying authentication problem when trying to connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Dec 30, 2012 | Archos Arnova 10 4GB 4)
Amazon Kindle Fire HD Logo
266 people viewed this question
Top Amazon Tablets & eReaders Experts
Sheldon Dedek
William Alequin
matt
matt
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
