Question about SanDisk 4GB microSD High Capacity Memory Card
Nikon d50 camera 2 gb flash card how to format
Format d50 nikon camera
Posted by evan friedman on
2 Related Answers
Anonymous
  • 33 Answers
SOURCE: compact flash card 4 GB
I'm going to go out on a limb and predict that you have never tried a 4GB card in this camera before.
After looking at the manual, this camera, a 2001 product, would seem to be from a time when 1GB cards were still off in the future, and 4GB cards were not even conceivable.
So that you know, the manual refers to a 160MB card as the highest option available at the time, but I have to think that 64MB was considered a large card back then.
The link for the manual is: http://www.nikonusa.com/pdf/manuals/coolpix/CP775man.pdf
The page I'm referring to is page 154 (which is actually page 168 of the pdf document).
I suggest you contact Nikon and ask for an update to the compatible flash cards for this camera and find a 256MB or 512MB that someone has lying around.
Posted on Feb 12, 2008
Anonymous
  • 95 Answers
SOURCE: Sandisk 8 GB CF 60mb/s card just quit working and
Try formatting on computer.
Posted on Mar 07, 2011
Nikon D50 powers up but none of the functions work. Battery indicator flashes but battery is fully charged. No memory card also flashes though memory card is inserted correctly.
Hi Have you tried resetting the camera back to factory settings? This should clear up any problems...if it doesn't it may at least let you know what the problem is? Also...do not use an SD card no bigger than 2 gigs, What is thee display showing? Make sure the date and time are correct! Get back to me if you need any more help...Thanks...John,
CHA is showing on disply screen
1. Use Nikon approved card
2. Check the mediea card for Damage
3. format the memory card or delete files on the card
2helpful
D50 cannot use a 4gb card??? I use 1gb, 2 gb and no issues, now bought a 4gb card and get a CHA indicator on camera and will not shoot pictures. Can this camera be programed to accept a 4gb or larger...
No, the D50 will not (as you've discovered) accept an SDHC memory card (anything bigger than 2gb is SDHC). I haven't found a firmware upgrade for the D50 to rectify this issue, either. I own a D50 also, and love it, but bigger cards would be nice.
Problem with sd
According to the web page for this model, the camera is compatible with SD cards (only). The SD card protocol handled up to 2 GB. The SDHC card works with a different protocol, and digital devices made before the SDHC card came out may not be compatible with the newer protocol.
3helpful
2answers
Cant use 4gb sd card in my camera why?
The D50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will only work with devices specifically designed to accept SDHC cards. The D50 wasn't. It only works with SD cards, 2GB and smaller.
My Nikon D50 camera says
It thinks that the SD card is full - try re-formatting if you have no photos there. The SD functions the same as a PC hard drive, and if the directory 'tracks' are corrupt, anything could happen. Else try a new SD card.
3helpful
2answers
Memory card flashes full when it's not
There should be a "format card" option in the camera's system menu. do this and it may help the unfortunate equipment realize the situation:) (be sure there are no pics you want to keep as they will be permenantly removed)
SanDisk 4GB microSD High Capacity Memory Card Logo
Top SanDisk Electronics - Others Experts
k24674
Ekse
Mehandi Husain ...
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
