Re: I turned the talkback feature on and now im locked...
Just make a factory data reset.
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
Depends if it is an apple or android tablet, and if it has a removable memory.
if it is a Samsung, remove the memory card, then factory reset the device. Yes you will lose some of your data but you will be able to access what us on the memory card.
Sort of the same story for an iPad
https://support.apple.com/en-us/HT211078#:~:text=If%20you%20can't%20remember,settings%20after%20restoring%20your%20iPad.
It appears to be your parental control feature, or lock function. Try the codes 3001 or 1234 to reset the lock feature.
Press: Menu>Features>Parental Control(Child Lock)>Select,
then enter the code.
in case it doesnt work...whats your TV make and model?
Sound like voice activation try and hold the volume buttons till it say talkback suspended press ok a few times quickly and then it will say talkback suspended
Verizon WirelessRegister · Home > Support > Verizon > Verizon Ellipsis 7 > Unlock the Device -Verizon Ellipsis 7 ... Learn how to use your tablet with our Interactive Simulators · View your User ..... Depending upon the screen lock type, do one of the following:.
Verizon WirelessVerizon Wireless Logo .... Home > Support > Verizon > Verizon Ellipsis 7 > Enable/Disable the SIM PIN - Verizon Ellipsis 7 ... Learn how to use your tablet with our Interactive Simulators ..... Personal Identification Number (PIN) locks the SIM card so it can't be used until the correct code is entered. ... Tap Set up SIM card lock.
Verizon · Verizon Wireless Ellipsis 7. 9 answers ... How do I reset my ellipsis 7when I don't remember the password or the email and it is stuck in airplane mode? ...About two months ago I purchased an ellipsis tablet from verizon. I do not ...
? 7:51
https://www.youtube.com/watch?v=NBp0qIorSOU
Dec 9, 2013 - Uploaded by Alabamas13
My review of the Ellipsis 7 tablet from Verizon Wireless. ... howdo you unlock the freakin puk code ijust bought it from goodwill now its locked.
I locked my tab with a pin lock and I forgot the code. ... Locked out of my Samsung Galaxy S2 i91000? .... can use, the following steps (as well as the video above) in order to help yourself to get back into your device by using a reset combination: .... Cannot get my screen on my tablet to unlock, don't remember pin number?
The easiest way out right now would be to reset your Tablet. Press the ... Yes ' No ' I need help. See more questions like this: I forgot my pin password on my o+ mobile ...My Android phone has been locked and it asks for Google accounts, but I don't remember which one I used. .... I've tried to break into it myself. How can I ...
My tablet wouldn't turn on, so I pushed the rest button that is located on the outside of the tablet. the screen come up with a pin code that is four numbers. it never had a lock on it, until I pushed the reset. I can't get in to the tablet. what do I do?
You will have to perform a firmware update to the tablet. Be sure to back up any information and data to your computer's hard drive as the tablet will be reset to a factory default setting and all of your data will be erased.A To perform this firmware update from your computer, log ontowww.southerntelecom.com/polaroidsupport and select "Updates". From here you can get the firmware update as well as the Firmware Update Guide.A Be sure to select the correct model number (located on the back of the tablet).
