Televison & Video Logo
A
Anonymous Posted on Feb 28, 2014
Green light flashes 3 times philips tv - Philips FTR-9964 Tuner/Receiver for Plasma
ANTHONY WHITE
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 02, 2016
ANTHONY WHITE
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
219
Points
6
Change power supply
Philips 37PF5521D green light flashes 1 long then 9 short
The fault code is '19'. Counting the flashes to philips TVs are given in detail by the link given below. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ You can get details about the fault codes, blinking codes etc:
I have a Philips 42pf5321d/37 that won't turn on.
send me a email [email protected] and I can assist you with troubleshooting it to determine whats happening with the set.
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Philips 32PT6441\37 will not turn on. Flashing
You need the Horizontal Timing Kit for your TV. Chassis # is L04.1U AA can be found on the back of the TV. The part# is 4835 310 57673, Have a tv tech install this for you.!!!!
2helpful
Philips tv powered off and wont turn back on
There is a smt located at 7404 [C-6 Bottom] A common problem, does the tv make a sound like it wants to come on? Location 3239 should be small resistor, 3414 another resistor and a driver transformer at 5402 if it looks burned. See MCM electronics website and see if there is a kit to repair this. Or ask for part #s as per location of problem area mentioned. What you will be doing is changing the timing so all the components will come on at the same time. If this is done correctly you will notice the top of tv screen will flash red, green and blue lines. This will be the new norm each time you turn it on. But it will be OK. This is what the flashing green light is telling you. signed the Green Lantern7!!!!!!!
1helpful
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
1helpful
1helpful
Philips 42PF9630A/37 PLASMA TV
Replace that board the part number is 996500032643. go to www.vancebaldwin.com for the price of the board.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
