Wheel initally with start making a washing machine noise or grinding sound when doing sharp turns the opposite of the wheel side as the outer race will generally go bad first. You may also notice the rim heating up due to friction. Grinding at low speed or a growling sound would dictate an inspection.
Check your connecting terminals on both ends for that channel that the polarity is correct and firmly connected. If you find no problem with that, then swap the connections...if the problem repeats to the other side then the speaker is damaged. If the problem stays on right side then it is the unit and needs to be investigated further.
so many things that can be wrong. First step is to take the working speaker from the right, and plug it in on the left. If it works, replace the bad spkr. If not, it's a wiring/electrical problem, and will need more testing..
try this, worked for me!
http://pdf.crse.com/manuals/4287511121/EN/contents/04/01/01/01.html#l2_limiting%20the%20volume%20[avls%20%28volume%20limit%29]
sounds like it may be bad wheel hub bearing. wen going down road with no traffic steer left then right left right and see if noise gets louder and softer wen weight shifts from side to side. if it does u may need to get new hub bearings
hi :)
i guess your sony phone has been long time use already right ??
normally,the sound.we call it buzzer slow.most the buzzer has spoil.
perhaps,compenet is also will make it.
u can send to nearby mobile shop for repair.
Good Luck.
