Question about Chevrolet Audio Players & Recorders
2001 chevy astro vaccum how to find - Chevrolet Audio Players & Recorders
Posted by Jonah Elkins on
2 Related Answers
roniecon
Ronny Bennett Sr.
  • 6927 Answers
SOURCE: I have a chevy astro van that has a broken heater vaccum line
some of them are dummies they are not vacuums,but if it is a vacuum line is it color coded?
Posted on Jun 28, 2009
Anonymous
  • 462 Answers
SOURCE: 2001 astro chevy van 4.3 engines need to set the timing
The distributor in that engine can only be installed in one position. The hold down is built onto the distributor meaning when it is installed and the engine runs the computer is responsible for the timing. The distributor will move a little but won't correct major timing errors.
Posted on Sep 13, 2009
How to replace the glass on the driver side of 2001 chevy astro van
Pull door panel easily and remove hardware to remove the glass and place the new one gently in place.
Dec 18, 2014 | Vehicle Parts & Accessories
Vaccum hose that controls the fan directional on chevy astro
purchase a haynes manual-its detailed in all parts of the vehicle--those discount places havum
Jan 01, 2010 | Chevrolet Astro Cars & Trucks
HOW DO I CHANGE THE SPARK PLUGS ON A 2001 CHEVROLET ASTRO AWD WIT
get in through the doghouse, you will need a flex head ratchet and different lenght extensions
Nov 18, 2009 | 2001 Chevrolet Astro
How to disconnect drl on a 2005 chevy astro
Should be a fuse in fusebox labeled 'DRL/FOG'. Just pull it out.
Oct 07, 2009 | 2001 Chevrolet Astro
Jun 28, 2009 | 1997 Chevrolet Astro
Ac controls
selector mode switch is bad
May 24, 2009 | 1998 Chevrolet Astro
Can I down load the codes from my 2001 chevy astro?
on a 2001 you need to go to any parts store and they can read the codes for you.. good luck keith..p.s. this service is free to the public..
Mar 19, 2009 | 2001 Chevrolet Astro
Need to change thermostat in 01' Chevy Astro Van
It is located where the big hose comming out of your radiator connects to top of engine. Remove hose from engine your thermostat is undernieth
Nov 15, 2008 | 2001 Chevrolet Astro
Hvac doors not working
Its probably the vaccum line. Check again. There is a small thin one that crosses over the top of the engine and fails/leakes/cracks in the area where it is hard to see. Repalcing the vaccum lines for $10 is the place to start. Then see what happens. While the engine cover is off, go ahead and change the PCV valve and give the engine a quick check for any other loose connections or issues.
Nov 13, 2008 | 1999 Chevrolet Astro
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
