Question about Haier Refrigerators
Haier defrost timer location Refrigerators hrf-350
Posted by arslan malik on
Bea V
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 76 Answers
Www.manualowl.com/p/Haier/HRF-588FR/Manual/99803
Posted on Mar 07, 2014
5 Related Answers
22yooper
James Helmer
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Posted on Aug 25, 2008
Anonymous
  • 93 Answers
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
Posted on Mar 15, 2009
Anonymous
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: WHERE IS THE DEFROST TIMER LOCATED ?
Hi
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 31, 2009
Where can I find one
might have to be a used one
some sites mark that model is out of stock
found the user manual for it
http://souqmobi.com/electronics/haier-hrf-321-sl-refrigerators/
depends on what side of the world you are
Dubai UAE link ?
May 20, 2016 | Refrigerators
How can i operate the temperature of the haier fridge model hrf-660aa
do you hear the compressor come on? can u feel it vibrating? if not? bad relay maybe? is there power from the outlet? may also have a bad cold control thermostat or defrost timer? is ther any heat in the freezer compartment?
Feb 16, 2015 | Haier Refrigerators
Defrost timer location
Check this out for manual: www.manualowl.com/p/Haier/HRF-588FR/Manual/99803
Feb 28, 2014 | Haier Refrigerators
Sir i have haier refrigerator hrf 368u its freezer is working making ice but lower portion is not working properly. it is a direct cooling system without frost free
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 28, 2011 | Refrigerators
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Fridge will not get cold
Was your fridge transported upright at all times? There are warnings on most brands not to lay them down due to potential damage. If that was not the case, those small units are often easy to repair.
[Note to garing: The person said there was no ice anywhere but on the back. Dorm sized refridgerators are rarely frost free, so your answer was pointless.]
Aug 17, 2009 | Haier HSB03 Compact Refrigerator
How Do i have a Haier HRF-388AE, Do you know how to defrost the Freezer while leaving fridge on?
CAN'T BE DONE AS THE FRIG WORKS OFF THE FREEZER,THE FREEZER MAKES ALL THE COLD AIR FOR FOR FRIG.IF IT'S NOT FROST FREE JUST TURN THE THERMOSTAT OFF TILL FREEZER IS DEFROSTED,IF FROST FREE YOU SHOULD'NT HAVE TO DO ANYTHING,HOPE THIS HELPS-MIKE
Jun 07, 2008 | Haier Refrigerators
Haier HRF-488FR/***
hi there, i noticed your post was in 08 did you find a seal to fit your fridge i have a hrf 488 fr/a and fisher and pykel are looking after them now... they advised be that this model is obsolete now and no longer have parts available.
May 19, 2008 | Haier Refrigerators
Refrigerators Logo
135 people viewed this question
Top Haier Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
