I'm running Windows 7 and it has always worked. Computer recognizes the device, but after RipRec error message when it goes to transfer the files. Software and Firmware have been upgraded to 3.0
SOURCE: Gigabeat System Error Problem
Error message 0000020 - System Error displayed whenevr devide powered up. Only way to shut down is by turning battery off. Gigabeat Software on PC not able to detect device, not listed in Device Manager or as an external drive in My Computer. (As it normally is) Is there a way to reinstall firmware from PC when device not detected?
SOURCE: I need to reset the entire program on the f40. System settings and all
The EASY but Time consuming way (If you Only hagve USB 1), is to just RESET the unit.
The manual will run you through it, and reload.
I have both Gigabeat Room, and Win/Player 11, and have reset and reloaded a few times.
Just take some time (Specially with Gig Room)
Good Luck
SOURCE: Computer does not recognize Gigabeat Device
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
SOURCE: I would like to copy or remove music files from gigabeat to my pc.
plug in the ipod, go to my computer and double click your ipod icon, go ta music, and then copy and paste what you want to " my music"
SOURCE: Is transfer from Gigabeat to iPod possible?
There are programs like sound taxi that will do it easily but they do charge for them. If all of the files are on your computer just add them to iTunes and they'll all transfer to your ipod. If not just transfer them from your Gigabeat to your computers music file. Add the file to your iTunes and then sync your ipod to your computer and all of your songs will be on your ipod. Unfortunately without paying for a transfer program you will loose all of your playlists and organization files.
