Above issue described
The "Er dH," also known as the Defrost Heater Error message, is displayed when the unit fails to reach 46? F within 2 hours of beginning its defrost cycle. This may be an indication of the defrost heater having broken or the temperature fuse having been pulled out of its slot. Contact customer service if the problem persists after having attempted a system reset.
Quick Fix
Defroster Problem
Repair
Read more: http://www.ehow.com/info_8705867_lg-refrigerator-error-code-erdh.html#ixzz2udv3MZKA
SOURCE: LG LRSC26923TT freezer not freezing error display
You have a defrost problem that requires a service call from a qualified LG technician.
SOURCE: where is this fuse located on the LG refrigerator is displaying a ER DH code error
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
SOURCE: Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service
Manual
"Er dH" seems to be a defroster issue.
SOURCE: Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
SOURCE: LG LRFD25850ST gives ER CO code on door
Good call Cooltech! My new LG "open box" deal from Best Buy must have been delivered once before. I hauled it home, plugged it in and Er CO was on the display. The doors must have been removed to get through tight spaces, exposing the bundle of wires and connectors under the left hinge cover. One wire had been repaired with a crimp lug, wire cut too short, and the crimp was no good. I soldered the connection and added 2" of wire so it wouldn't be stressed. Works!
