Question about Coby Kyros MID70154G 7 Tablet Computer TTC8902 800 MHz 800 x 480 WVGA Display Android 21 HDMI
It is a white screen with a blake dot
It wont turn on to the screen
Rca tablet model rct6272w23 screen pixalted white then went black now wont turn on
I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
Dec 28, 2014 | Tablets & eReaders
Xelio 4gb wont turn on
Had same problem, turned out to be fault in firmware operating system, replacement tablet.
Mar 22, 2014 | Tablets & eReaders
I have a kindle that wont come on an its charge up
First off, I've had 5+ of that type of kindle. Each time the screen was cracked causing the screen to not turn on. If you see any lines this is definitely your problem. If so, you can either replace the screen or replace the kindle.
Mar 11, 2014 | Amazon Kindle 3G
My tablet wont turn on
if the charge light comes on then the unit may need to be replaced. Try connecting it to a PC to see if it detects it. If it does, you may be able to reinstall the firmware.
Feb 12, 2014 | Coby Kyros 716829701508 Tablet PC
Screen wont turn back upright
Swipe down from the top. A band of icons appears. Look for the rectangle (top left I think) This is the Screen Lock Icon. Tap it to turn screen Lock OFF. (Or on the EFun it may be a Wheel icon for screen lock.)
Jan 20, 2014 | EFUN NextBook NEXT8P12 8" Tablet
Android Tablet wont turn on.
CONNECT TO POWER SUPPLY .... PRESS ON BUTTON (20 SEC) THEN ... WITH OTHER HAND / FINGER KEEP TAPPING SCREEN .... REPEAT UNTIL TAB WAKES UP
Jul 22, 2013 | Google Android 4.0 7 inch 1080P Video...
My tablet wont slide the unlock button
Hi Did you solve your problem I am having the same problem
Mar 26, 2013 | Disgo 6000 Tablet
Coby Kyros MID70154G 7 Tablet Computer TTC8902 800 MHz 800 x 480 WVGA Display Android 21 HDMI Logo
Top Coby Tablets & eReaders Experts
Marvin
Marvin
Lawrence Oravetz
Edward Morgan
Edward Morgan
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
