The kindle is asking to be charged but when I connect the charger, nothing happens
Use a different charger - se if any of the ones you have for your phones are Micro USB - they will charge it fine.
If not get a usb/micro usb cable or micro usb charger from most shops in the high street for 4 or 5 pounds.
If using the usb jack on a pc or laptop swap to a different usb jack on the pc or laptop
SOURCE: My kindle will not charge. I plug it in and there
If you've explored all options with software settings and If you're outof warranty, you can try to open the kindle and replace the battery.There is a Kindle Repair Guide that shows you how to take it apat. There are services that can do it for you. Kindle Repair.
SOURCE: The kindle screen is frozen on the sleep mode, the
Try a different charger. If that fails too, you have a logic board issue. Amazon should give you a replacement. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
SOURCE: I have a kindle and connect to usb on a Windows 7
I guess you're trying to eject the Kindle from the task bar "(safely remove hardware". Try going into Start/Computer/right click on Kindle/ select eject. This worked for me when I had the same problem.
SOURCE: When I picked up my Kindle to read it today, the
my kindle has frozen 3 times when trying to search the web, we have only had it for 3 days, what gives....not happy
SOURCE: I have an Amazon Kindle
You may have a common problem, for which you should check the Kindle FAQ at http://www.amazon.com/gp/help/customer/display.html/ref=hp_cu_T16_518316_ph_kindle_supp?ie=UTF8&nodeId=200127470#FAQs
If your Kindle is still defective after looking at the troubleshooting advice, you can contact Amazon via the "Contact us" button on the right hand side of the page linked above. Your Kindle is covered by a 1 year limited warranty, so if it is broken Amazon should be happy to replace it.
