Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Color! colors are all dull or faded. Red around the edges of picture.how can I solve the problem.
Posted by solpowerelec on
ginstervrt
    Scholar:
  • 86 Answers
The dull and faded color could mean you need to change the coolant.
you could also try and adjust your convergence.
Posted on Aug 06, 2009
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
Colors seem to be out of sync
Dull Video...
Convergence
May 14, 2010 | Philips 55PP9401 55" Rear Projection...
The red and green colors are at the edges of the picture and it's blurry
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 12, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Color is off, very red green have auto corrected and also tried manual color adjustment. still not correct mitsubishi wd 52627televison
These sets have several common problems which are listed below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV may have one or more of the following symptoms....
You can see some more examples and find the fix here...
Apr 03, 2010 | Mitsubishi WD-52627 52" Television
Red color does not align
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Apr 03, 2010 | Televison & Video
Picture quality of colours fading
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 05, 2010 | Philips 60PP9202 60" Rear Projection...
Picture is fading in color
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Jan 27, 2010 | Philips 51PW9363 51" Rear Projection...
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Phillips 43" T.V sound is fine Picture is Faded? Still visible but very light and faded..How do I fix
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 06, 2009 | Philips 43PP9202 43" Rear Projection...
Color fading, orangy red, video adjustments don't fix.
if it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
Apr 08, 2017 | Televison & Video
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
319 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
