Sony Ericsson G502 Cellular Phone Logo
A
Anonymous Posted on Feb 28, 2014
Enter combination and password - Sony Ericsson G502 Cellular Phone
2answers
How do i reboot a dell optiplex 960 to factory settings if i cannot login?
How to enter BIOS?
1. Turn on or restart your computer.
2. Press "F2" to enter "System Settings" (BIOS) when the DELL icon appears.
Restore the BIOS to default settings.
Press "Caps Lock", "Num Lock" and "Scroll Lock" buttons to light up the corresponding lights on the keyboard. Then, press the following three combination keys:
Alt+E - Clear (Release) the interrupted resources and reallocate resources at next startup. After pressing the combination key, you will hear a sharp beep tone.
Alt+F - Restore BIOS to the default settings. After pressing the combination key, you will hear a sharp beep tone.
Alt+B - Restart the system.
Password clearing method 1: When the password input box appears, type in the password and press "Ctrl" and "Enter" simultaneously.
Password clearing method 2: Remove the PSWD jumper on the MB and start up the system. Set the password to empty in BIOS, shut down the system and reconnect the PSWD jumper.
Hope this method will help you otherwise check Dell Optiplex 960 Manual- https://guideusermanual.com/product-name-optiplex-960-manual&po=344822&lang=English for expert's suggestions.
My Toshiba laptop has just locked and I can't
Try the Ctrl+Alt+Del key combination. It should give you the password box to type in the password.
S/n & password
192.168.0.1
username-user
password-user
you can also try a combination of user and password or leave the username spot blank and just enter password for the password or username is admin and the pasword is password or username is admin and the password is admin. Hope something works.
Temporary password
Temporary passwords
After you enable login verification for your account on the web, you'll need to use a temporary password to log in to Twitter on other devices or applications that require you to enter your Twitter password; you will not be able to log in using your usual username and password combination. Some common devices or applications that require a temporary password are: mobile.twitter.com, TweetDeck for Mac or Windows, and Twitter for Mac, iPhone, Android, Blackberry, and Windows.
To use a temporary password:
  1. Go to the Password tab of your account settings on twitter.com.
  2. Click the Generate button.
  3. Enter your current account password and hit Generate again.
  4. When prompted to log in to your other device or application, enter your username and use the temporary password that you were provided.
Source: https://support.twitter.com/articles/20170388-using-login-verification
Hope that helps!
My volumn on my ipod 4th gen is not working and when i go to settings it only shows languages no volumn setting
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
Under settings all it will show me is language there is no volumn setting-my sound is not working correctly
hope this helps
Change the combination to a Sentry 2260 safe. I have original combination and all I just need to change the combination.
Safe and vault techs would advise you
1. Press the Program key.
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Voicemail Lockout
Press the feature button then 983 enter 120000 as your password, if that doesn't work try a combination of 1020000, 10020000, etc... Enter the mailbox ext (The phone ext) hit reset and the password will be reset to 0000. You will be forced to change the password after you log into your mailbox again.
Reset vchip password
Hope that they didn't actually reset it and enter 1234. If this doesn't work, you'll have to play the "numbers game" and try all combinations...accordianman
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
