A
Anonymous Posted on Feb 28, 2014
Who sells drive- belts?
Belt broke
Sam Palermo
Level 3:
  • Sony Master 1,267 Answers
  • Posted on Jan 02, 2015
Sam Palermo
Sony Master
Level 3:
Answers
1267
Questions
Helped
256119
Points
1842
They are sold at Consolidated Electronics if you know the size and type otherwise you buy a kit from Marrs Communications
2001 eclipse serpetine belt broke put new ones on now car turns over but won't start.
2001 GT Eclipse Spyder..cranked this morning, both drive belts broke, harmonic balancer came apart..replaced balancer, belts, now it won't fire. I did find a piece of one of the drive belts intertwined in the timing belt. Thing is absolutely not getting any fire.
The belt broke and I need a new belt..only to find out that sears doesn't sell parts for the sears craftsman jobsite saw model JT2502RC
Huh??? According to my parts manual you need an "2YFD" belt. ereplacementparts.com has it for $3.88 be sure to check that this is the belt you want BEFORE ordering it.
Sears should have it. How do you know Sears does NOT sell this part?
1helpful
The driver belt came loose on the Xerox DocuMate 632
I am a Support Engineer with Xerox Scanners.
If the Drive belt came loose or broke off from the scanner, the best suggestion I could recommend is to replace the scanner. We do not sell the drive belt to replace or fix the scanner.
We recommend to contact us, so we could provide you further assistance with your issue. Contact us at 800-648-0410.
Regards,
Xerox Scanners Support
1helpful
My belt broke and now my car wont start why not?
Ok. If your car was running and then the belt broke and you continued to drive it. The case may be that you drained the battery because the alternator runs on the belt and the alternator keeps battery charged and if belt broke and you continued to drive then you may need to jump start vehicle. I guess I shouldve asked earlier but have you replaced belt yet?
My wife has a 1994 chevy suburban,she was driving along and the serpentine belt broke, what do you think caused that to happen?
WELL I WOULD SAY BELT WORN HAD A BAD PLACE BROKE OR FAULTY DRIVE BELT TENSIONER CAUSING LOT OF SLACK IN BELT TO BREAK.
3helpful
2answers
Timing belt broke is this a low tolorance enging
A 1991 GEO is worth scraping if this is your problem
A water pump is also needed to replace with the belt
It is a rule of thumb for the belt drives the pump as well
Think about selling it to a local kid as his first car that he has to fool with. The monet to fix it is really not worth investing into it
The fuel pump for these cost more than the worth of this car now
Broken belt
The web site below sells Gilson belts - you need the part number. If you do not have the part number, maybe if you contact them, they can match the belt to your tiller number.
http://www.psep.biz/store/gilson_tiller_belts.htm
Also, another web store, Jacks small Engines (jackssmallengines.com) states that they carry parts for Gilson, but I did not find Gilson in their directory. You may have to contact them.
One of the web sites mentioned that at some point Gilson was bought by Lawn Boy. If you go to a local Lawn Boy dealer, they may be able to match up a belt.
I have a 1978 WheelHorse tractor. The drive belt for the mowing deck broke. I went to Home Depot, spend a good 1/2 hour measuring belts, and found one that works perfectly. If you go to your local outdoor equipment shop, especially one that sells, repairs tillers, they may be able to match up a belt for you. A belt is a belt is a belt. If you go to a "good old fashioned shop" that will spend the time, they can measure the old belt and hopefully come up with a match.
Good Luck!
Jul 29, 2009 • Garden
4helpful
Can't find replacement belt for Zach & Dani's coffee roaster
After we got over our anger of Nesco/American Harvest using 'insurance reasons' for not selling the drive belt to repair our roaster, we went to Office Max and purchased a bag of (10 @ $2.44) Alliance 'X-Treme' file bands (good ol rubber bands) they are 7" stretchable in size, and these particular ones are the new EPDM formula, which adds durability, last longer and is latex free so they don't dry out. This was extremely easy to fix vs packing and sending the complete unit to WI and then paying twenty some dollars for repair and waiting three weeks plus for return not to mention postage to and from. I've roasted three batches (including testing) so far and we are on the same rubber band. Works very well for us
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
