With his consent I have been able to get internet access via my Smart TV & PS3,...however the signal is poor, real poor. So my questions are,..Can I use my WRT120N to get a better signal? If so, how would I setup to his 10.0.1.1 IP? Can it be done wireless only? Can I do it in a manner that won't affect his speed or connection? Finally,..how would i connect my TV and PS3 to the router? Of course all these are assuming that it can. Thank you.
SOURCE: Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
SOURCE: have wireless router in other room PS3 setup can't connect www
SOURCE: Network setup questions.
You could program the MAC addresses of only the computers you wan't to be able to connect to the router. It seems like you could add the MAC of your girlfriends computer your business computer and any other specific computer you wan't to allow to connect and this would leave all your current securities in place. Here are instructions if this solution sounds like what you need. http://www1.linksys.com/support/troubleshoot/wireless/wireless_router_config/wireless_mac_filtering.html
SOURCE: I'm using TP-LINK TD-W8101G ADSL
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
