Question about Brother HL-2240 Monochrome Laser Printer
Wont stop paper feeding
Just installed today and it won't stop paper feeding. Shows 2 docs in file..I delete and then they come back and it starts to run the papers again.
Lukas Menelaou
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • Brother Expert
  • 234 Answers
Check the Remaining Print Jobs in your PC and Delete ALL OF THEM
Posted on Aug 01, 2014
Will not feed 11x17
You probably need to set the user settings to "long doc" mode.
1) When the machine is in the standby state,
press the NEW FILE key and Count Only key
simultaneously. During the user mode, the
LEDs of the NEW FILE key and Count Only
key illuminate and the address (U01-U10)
and data (the last digit) appear on the
counter display.
2) When changing the address, use the NEW
FILE key. Each time NEW FILE is pressed,
the address changes, cycling from U01 to
U10.
3) When changing the data, use the Count Only
key. Each time Count Only is pressed, the
data changes.
4) Pressing the Stop key exits the user mode.
Long document mode =U10; 0=normal and 1=long document mode.
Happy Scanning!
Scan-R-Store
Scan Store provides service and maintenance contracts on all Canon Fujitsu...
Apr 02, 2014 | Canon DR-9080C Path-Through Scanner
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
Lexmark x1270, installed on new Dell, will scan/print once but print queue won't clear after printing, and further jobs just back up in queue. Once, after trying reboot, printed next doc but that was...
Try to follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Aug 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
Won't print Dell V305
It seems to be an issue with the Print Spooler Service. Either the service is stopped or not started correctly. Try stopping and restarting the printer spooler services on your computer. For tips on how to restart the Print Spooler service, use the link: http://www.ehow.com/how_2319117_restart-print-spooler-xp.html. Now Reboot your system and try deleting the print queue. It should work fine now.
Good Luck!
-Abhishek
Jan 31, 2010 | Dell V305w All-In-One R840635AU InkJet...
Forces manual feed of paper whenever printing WordPerfect doc
Is a WordPerfect problem.
In WordPerfect go to file/page setup/select letter (or whatever)/edit/source - set to auto select.
Problem solved!
Jan 22, 2010 | Brother MFC-7820N All-In-One Laser Printer
I bought a printer from Btother MFC3360C. The paper didn't feed. I attempted many times to get it to work by trying to print some things. I finally fixed the paper problem and the damn thing starts pr
those buttons dont stop whats in the queue. You need to go to your printer icon, right click and select the first tab on the list, from there, you will see all the files being dumped to the printer, right click file and select delete, this will erase everything in the buffer.
thanks adi
Apr 24, 2009 | Office Equipment & Supplies
HP5510 Printer not working
WHAT IS THE OPERATING SYSTEM THT YOU ARE USING
IF THAT IS xp OR vista
GO TO THE PRINTER SPAGE AND RIGHT CLICK ON THE PRINTER AND SELECT RUN AS ADMINISTRATOR
SELECT CANCELL ALL DOCUMENTS AND SEE IF IT CLEARS THE PRINT QUE
STILL IF IT DOES NOT DELETE THE PENDING DOCUMENTS
GO TO SERVICES.MSC WHICH YOU CAN TYPE IN THE START SEARCH OR THE RUN BOX
LOOK FOR THE SERVICE NAMED AS "PRINT SPOOLER "AND MAKE SURE THAT THE SERVICE IS STARTED IF THE SERVICE IS ALREADY STARTED RESTART TEH SERVICE TWICE OIR THRICE
AND THE DOCUMENT WILL GET CANCELLED
BEFORE GOING AHEAD AND PRINTING TRY PRINTING A TEST PAGE FROM THE PRINTER P[ROPERTIES PAGE AND THEN TRY PRINTING OTHER DOCUENTS IT SHOULD PORINT OR ELSE GET BACK TO US AND WE WOULD BE MORE THAN HAPPY TO HELP YOU
THANKS AND REGARDS
HOPE THIS SHOULD WORK
BEST OF LUCK
Hamid
Apr 03, 2009 | HP Office Equipment & Supplies
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
File storage is full
here is the manual, look at page 9 of the e-manual for the function keys.
# 9 Edit file mode ----Print file. ( also shown on pge 81)
shows how to delete the file also.
Good luck
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=412914c5b54b5add014416140dfd72ec&q=panasonic+uf+585+manual
Sep 19, 2007 | Panasonic Panafax UF-585 Plain Paper Laser...
Brother HL-2240 Monochrome Laser Printer Logo
77 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
