Question about West Bend 56860 10-Cup Coffee Maker
Strong plastic odor in West Bend coffeemaker
My new programable 10-cup West Bend coffee maker has a strong plastic odor that affects the coffee. How do I remove the odor?
Posted by dnewman1 on
Nate Stansfield
  • 11,896 Answers
Oh yes. This must be a new machine. I would recommend pouring and draining boiling water in the maker several times. You can also use vinegar, but again it has to be rinsed and refilled and rinsed again with boiling hot water.
Posted on Jun 11, 2009
Need a new coffee basket it is plastic the number is 7036.
You can order a replacement basket online from either of the the following sites:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=948&secid=87&linkon=subcategory&linkid=125
or
http://www.abtecparts.com/westbend_urn_baskets.htm
The P122-45 should fit your coffee urn. West Bend has 2 different 36 cup coffee urns, both use this same basket.
Thank you for using FixYa!
Sep 19, 2011 | West Bend (58036) 36-Cup Coffee Maker
Coffee to water
The Instruction Manual for the West Bend Coffeemaker can be found here:
http://www.westbend.com/supportdata/L5590A_Coffeemakers_ALL.pdf
See page 4 for amount of coffee to use.
Water Level Amount of Ground Coffee
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Use electric perk grind coffeeror coofee ground for all coffeemakers. Do not use drip or finely ground coffee.
Mar 19, 2011 | West Bend (58036) 36-Cup Coffee Maker
We are trying to figure out how much coffee to how much water for 55 cups. Is the cup designation for an 8 ounce cup size?
This is so subjective.... NYC vs The midwest, the answer will be different. If you look closely at the coffee basket there will be an indicator that will show where the ground should be leveled to. When I made coffee in NJ we used this style and sized pot for all meetings and the "rule of thumb" was 3/4 lb for 55 cups (this was not strong enough for me. Try it at that level and adjust. If it is terribly week you can drain a pitcher of coffee then add another cup of new grounds to the basket and pour over the grounds. Good luck
Jan 22, 2011 | West Bend 13500 Coffee Maker
How much coffee do you use to make 30 cups of coffee and how long do you brew it?
I like it strong... so I use one measuring cup for every eight cups or in your case about 4 cups...
heatman101
Aug 10, 2010 | West Bend 58030 Coffee Maker
Coffee to water ratio
Weak coffee is 2 tsp per cup strong coffee is 3 tsp or 1 Tbls per cup. (3 tsp per Tblsp) 32 Tablespoons = 2 Cups, there are 4 Tblsp per 1/4 cup. If you're confused ( I am from reading my answer) Use 1 cup for weak coffee, two cups for strong or 1 & 1/2 for regular strength coffee. Hope that helps!
Apr 11, 2010 | West Bend (58036) 36-Cup Coffee Maker
How many cups or scoops of coffee for 36 cups of water
We use this weekly at church and use 2 1/4 measuring cups for 36 cups. This is medium to strong strength, very popular.
Nov 26, 2009 | West Bend (58036) 36-Cup Coffee Maker
How much coffee do you use for 36 cups
The standard is one measuring spoon per cup...if you like your coffee strong, or if your cups are big, double the amount.
Oct 02, 2009 | West Bend (58036) 36-Cup Coffee Maker
West Bend 56860 10-Cup Coffee Maker Logo
131 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Paul Bade
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
