Cannot open clasp prestige replica rolex
1)Unscrew the crown until it pops out, the same way you would unscrew the crown to change the time on the watch.
2)Place the watch case opener in the notches around the outside of the back of the watch case. You have to use a watch case opener made for Rolex watches to open the watch. Once the case opener is in place, twist it and the back will pop open.
3)Use a mini screwdriver to loosen a tiny screw on the inside of the watch located near the stem. You do not need to unscrew fully--only loosen it.
4)Pull the crown straight out. The crown and stem should come out easily.
To open the back of the watch
1)Purchase a Rolex watch back opener set, if you do not already have one. This set is able to open and close any size of Rolex case.
2)Match the size of your Rolex case with the same size of grooved metal die from the tool set.
3)Put the metal die on the grooves on the back of the watch case.
4)Turn the die to remove the case.
5)Remove the rubber gasket.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
