Blueant Supertooth Light Bluetooth Speaker Car Kit Logo
Posted on Jun 11, 2009
How do i sync supertooth light to a new mobile phone
My mobile phone is a nokia
I808
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jun 15, 2009
I808
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
10682
Points
86
Turn the blueant off by holding the green button until it powers down. Put your phone in discover mode (refer to your phone's manual) then power the blueant back up but hold down the green button until the light starts flashing red and blue. Now you should be able to see it on the phone. I just discovered my Samsung I910 wouldn't pair unless I used the windows on screen keyboard instead of the Samsung on screen keyboard.
5helpful
My nokia E71 will not pair up with the Supertooth Buddy. The phone cannot seem to locate the buddy. the Bluetooth is on! Do you know why?
I had the same problem as you. I took the following steps to solve it.
- Powered off both devices.
- Turned on the Supertooth by holding the powerbutton until light alternates red/blue.
- Turned on phone, enabled bluetooth.
- Went to Connectivity->Bluetooth->(right)->options>"New paired Device".
It finally managed to pair the device.
Had to enter pincode (0000, which is default for all supertooths).
Hope it helps.
39helpful
I have lost my instructions for my Supertooth Visor Go Model No. BHSTLGO and I need to pair it with my new mobile phone?
With the Supertooth switched off, press and hold (for 5 secs) the on/accept button. The lights will flash intermittently.
Then set your mobile phone to search for pairing on Bluetooth. When asked for a code type 0000 (4x zero)
Then the set will be paired.
I have just been given one for christmas and have just done it with my iPhone. Easy as peasy !!
9helpful
2answers
I have a BlueAnt Supertooth BTSLBC3 car speaker that won't pair up to my new BlackBerry curve 8530 phone. The BlackBerry won't see the BlueAnt Supertooth BTSLBC3. The BlueAnt Supertooth BTSLBC3 is paired...
Pairing Your BlueAntStep 2: Activate Pairing Mode on the Supertooth Light
  1. If the microphone arm is open, close it to turn the Supertooth Light off.
  2. Press and hold the answer button.
  3. With the answer button held down, open the microphone arm.
  4. The lights will start flashing red and blue, indicating that the Supertooth Light is in pairing mode.
You now need to activate Bluetooth
Hi, i have a supertooth light BTslbc3 and it has
Did you DROP the BTslbc3 from your old phone? If not, it may not pair with the new one. That is just a suggestion you may want to try. It may not pair with the new if it is still paried to the old. Hope this helps.
Lost instruction manual for supertooth light
Go to here to download it-
http://www.nokia.co.uk/support/product-support/nokia-6120-classic/guides
Hope this helps
Jim
18helpful
2answers
Blueant supertooth not pairing to samsung omnia i900
Hallo Stu,
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
4helpful
How can i reactivate my blueant blue tooth on my motorola ic902?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
8helpful
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
235helpful
5answers
Pairing problem for Supertooth btslbc3
-----How to Create a new Connection----
Pairing with Phone
1. Turn off all devices (ST Light and Phone)
2. Turn on Phone
3. Goto Bluetooth menu on the phone (might be in connectivity)
4. Go to device list or paired devices (make sure bluetooth is turned on)
5. Delete any old profiles that are still in there.
6. Goto the Supertooth Light (BlueAnt)
7. Hold down the green button (send button)
8. while holding it down, open the microphone
9. the light should start to flash "red" and "blue" (you can release the green button)
10. go back to your phone, and go into either 'device list' menu or 'paired devices' menu on your phone.
11. click on either search, add or new devices. Function depends on different phones
12. when the phone has found the device, it should say 'ST Light BA V1'
13. select it, then enter passkey "0000"
14. If your phone ask for authorization or auto connect, just click "yes"
Bluetooth
On most phones, you'll go to: Settings > Connectivity > Bluetooth > (turn on) > Phone visibility (shown to all / on) > Search for devices >Choose headset (when located) >>
The password is 0000 (four zeros)
I don't have the link for the Super tooth II manual. but here's the link for the Supertooth One manual: (it may help)
http://www.supertooth.net/img/one/mdp_EN.pdf
You'll need Adobe reader to view it. It's free. Download here if you need it:
http://get.adobe.com/reader/
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Top Blueant Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
