Question about Stanley Measuring Tools & Sensors
Can not change imperial to metric on stanley tlm160i
Lost manuel for stanley tlm160i
5 Related Answers
Anonymous
SOURCE: how do i change the measurements from metric to
click on the wii bottom (lower left) from the main menu. click on settings on go to languages click on the United states to get your measurements in pounds.
Posted on Dec 31, 2009
Anonymous
  • 66 Answers
SOURCE: Changing metric to Imperial on Suunto Vector
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
It's in the manual. I did it on mine.
Posted on Aug 03, 2010
Adrian Slack
SOURCE: I have a set of
Just press the on off then press it again quickly
Posted on Jul 22, 2012
H David Sims
SOURCE: conversion fom metric tyre to imperial tyre
In 1989 Jaguar may have been using same bolt pattern as Chevrolet and some other GM types. Check bolt pattern 1st, then chech offset. Jags tend to be high positive offset. I have a 2004 XJ8 VDP and the wheel bolt pattern is that of a Ford Taurus. Guess what kind of wheels I'm shopping for.
Posted on Aug 04, 2012
skychief2001
Stephen
  • 21873 Answers
SOURCE: how to change temperature display from Imperial to Metric
It should be in your owners manual if it can be done.
On some models there is a us-metric button for the display or you can go into settings in the computer and change it there.
Posted on Oct 01, 2012
Have 2011 cadillac dst, the speedometer changed from english to metrics, checked manual, says english, but still reads metrics
Hi. You would select Language for English. You need to scroll and select UNITS. From there you can choose between US, Metric and Imperial.
Aug 20, 2018 | Cadillac Cars & Trucks
My dodge journey 2015 change to miles from km I would like to change it back
Hey, all you need to do is change your settings from imperial to metric or metric to imperial.
Your owners manual will have the exact steps on how to perform that, be sure to give that a good read if you haven't yet about 15 minutes and you'll learn a whole lot of cool features you might not have known about your car yet.
Nov 07, 2017 | Dodge Cars & Trucks
How to find diffrent unit standerds relating to boilermaking
The basic principle is that it would use the customary or legal standard units for the particular country.
For instance in the US, although the metric system is legal, the American imperial (modified British) system is still used. Hence boilermaking specs and drawings would usually be in inches, feet, US ounces and pounds etc.
In Australia it has all gone metric long since, and units are in metres, mm, grams and kilograms etc. Boilermaking as a trade is nearly dead, but would be metric.
In the UK all packaging and food sales must be in metric units, but otherwise metrication is self-regulating and more or less voluntary. Because of the vast amount of equipment and tooling which has still imperial units inherent in it, much manufacturing there still uses imperial units. Boilermakers could see either system.
Mar 20, 2017 | Cars & Trucks
The number on the fan control in My 2005 pontiac grand prix and degree are in celsius. How do I change that.
My Buick has a button on the dash that says ENG / MET This changes everything from Imperial to Metric. Even the speedometer so you have to be careful In Ontario our speed is metric 100 is actually 60 miles per hour but if you push this button to imperial you have to adjust your speed to 60 Our signs are all metric.
Oct 16, 2016 | 2005 Pontiac Grand Prix
What size fasteners gs1000 1982
they are metric unless someone lost a screw and found any bolt for it but the are normaly all even numbers 8 10 12 14 ect.
Feb 11, 2014 | Suzuki Motorcycles
How to change temperature display from Imperial to Metric
Oct 01, 2012 | 2001 Toyota Camry Solara
Can this model be changed fom Metric to Imperial? Thanks Model pedometer HJ-112 by Omron
Why do you want to change it from Metric to Imperial? Omron Pedometer works really fine and I don't think there's any need to change it.
Jul 21, 2012 | Omron Healthcare Hj112 Pocket Pedometer
How do I change from Km to Miles on the odometer for a Rav 4 (2006)?
Disconnect the battery for 90 seconds, then unplugged the cluster.. Then connect the battery with no cluster.. HVAC display changed to metric...
Re-connected the cluster again, display changes to imperial...
The cluster is what dictates what is displayed. It is metric by-default but a US imperial instrument cluster overrides that.
Jun 29, 2011 | 2008 Toyota RAV4
Dec 25, 2008 | Suunto Vector Wristwatch
New Aqualand promaster dive watch JP1010-01L. Temperature currently displayed in C. How do I change display to F.
Called Citizen Customer Service and was told that there is no way to change it. These watches come set with metric or imperial scales from the factory and cannot be changed.
IT SUCKS !!!!!
Apr 21, 2008 | Breitling Navitimer A2332212 G5 431A watch
Measuring Tools & Sensors Logo
137 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
