Just had Sony TC-377 in for full repairs. While using microphone in either Channel (L or R) no sound is produced in the machine, record needles do not move no matter what the record knob settings are. I have checked the microphone and know that it works. When I go to record, the erase heads are doing their job, but the microphone input is not. am I missing something?
SOURCE: Repairing or replacing old tape decks
Hi m522posner
There is a surprising interest in "vintage" hifi products these days. Your tape machines probably needs new belts. Check this site out. You can get spares for your tape machine here. Belt kits are $17. He does repairs also, but the transport to and from may be an issue for you. I suggest emailing Bob, he may be able to refer you to someone in CA > I could do the repairs,but I am in Australia. :)
Vintage Electronics
P.O. Box 941
1241 Conestoga Creek Rd
Florissant, Co 80816
Email: [email protected]
You could have a go at freshening up the belts yourself:)
regards
robotek
SOURCE: Failure to record on left channel
al capacitors need changing due to age this will help but all the switches need cleaning if you live in england take it to audio gold crouch end they love these
Testimonial: "Thanks. Good information. Regret, live too far away from Crouch End. Still usefull anyway."
SOURCE: Sony TC-530 hum in internal amplifier left channel.
Electrolytic capacitors are good at causing hum. You could try replacing some of them, they are not expensive. Otherwise you might have damaged the left channel amp semiconducter, whatever that might be.
SOURCE: I can record on one side only, if I try to record on
It's a 4-channel recorder. That's four recorded channels in the same direction. You COULD use it like a standard 2-channel stereo recorder with bi-directional playback if you recorded only the front tracks. THAT would produce a 1/4-track stereo tape with two sides (directions).
In the photo, the front and back are clearly marked.
http://www.thevintageknob.org/SONY/sonyvault/TC7884/TC7884.html
Leave the Back Record switches in PB mode.
SOURCE: Sony TC 330 reel to
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
