Samsung SRP 350 Thermal Printer Logo
Question about Samsung SRP 350 Thermal Printer
Bixolon is printing weird - Samsung SRP 350 Thermal Printer
Posted by Paula on
My bixolon SRP 350PLUSII is double printing one receipt, please help me how to solve it
There is no option that I know of, on the printer to do this. I suspect this is an option in the pos software that you are using. If you are using windows try doing a test print to the srp350ii from the printers in control panel and see if it prints once. I am pretty sure it will and that will prove that it is something in the software itself.
1helpful
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
1helpful
I have bixolon srp 350 for my restarant when i give print command from register it always comes in queue with showing error. i done all softaware re installation and self test for printer everything works...
hello, im trying to send a print to my BIXOLON SRP350 Thermal printer by java codes. but java can't use the all the page width, what should i do to use all of the page width ?
I have replaced a posiflex receipt printer with a Problem with the POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer I have replaced a posiflex receipt printer with a bixolon...
If the print test works, then that rules out cables, etc. Definitely sounds like a comm setting issue. The most common problem with swapping serial printers is incorrect baud rate. Is that winpos from quest in Aus? I think they might use 9600 baud. You change the printer baud rate using the dipswitches under the panel on the bottom of the printer.
Needs MAc Driver for Samsung Bixolon Label Printer.
You might need to contact Bixolon and see if they support the Mac. I looked on their site and only found Windows drivers but they do have a contact button on the following link:
http://www.bixolon.com/_eng/download_center/downloadsub.asp?uid=495&p_uid=11
Best of Luck..
Have a Happy and Safe Holiday Season..
Hi there, I have bougth a bixolon print but it doesn`t work! the experts say I need the driver, where can i get obe?
Go here select your product, put in your information. download and install.
http://www.bixolon.com/_eng/bixolon_main.asp
Samsung bixolon SRP350plus is printing hazy
Thermal heads wear out over time as the paper grates down the thermal head. You'll get to a point where the only thing you can do is to replace the head. Contact the manufacturer or service centers to where you can buy one
2answers
Printing a logo for use in POS on a Bixolon Printer
you'll need to connect with Samsung directly, through their licensing group.
www.samsung.com
Top Samsung Office Equipment & Supplies Experts
Gary
Gary
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
