EVERY TIME I WASH A LOAD OF TOWELS IT IS TAKING FOUR HOURS TO COMPLETE. THIS HAPPENS ON BOTH HEAVY AND NORMAL CYCLES. IT SEEMS TO GET STUCK ON THE RINSE CYCLE BUT NO ERROR CODES APPEAR.
SOURCE: I have an error code
My husband opened the back panel and gave the drum a spin to get it going again. I believe ours errored due to being unlevel.
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
SOURCE: Wont drain or spin
I think simply your drain pump motor is stuck for what ever season. open it up and check. You will never get a spin condition if the water has not drained sufficiently.
SOURCE: Brand new. Load gets stuck on 14 minutes or some
Sounds like you are probably doing a very bulky or real off balance load on a high spin speed setting. The washer is trying to get the load up to spin speed, but the load is too off balanced. Try the lowest spin speed setting for that load. If it makes it through that, then power machine back on and just push the spin speed button until the next higher speed shows up, and then the start button if you want to spin it out better. If it still didn't make it through the original cycle on the lowest spin speed, your load must be way too off balanced, like one coat that is saturated with water. If that is the case, you may even have to squeeze some water out of it by hand before you would be able to get the washer to get it up to spin speed.
