Had problems with old mouse but keyboard was still OK. Bought a new logitech mouse but keyboard cannot pick up the new small receiver?
SOURCE: Logitech EX110 - Keyboard stoped responsding
reconnect again the connection between keyboard and pc
SOURCE: logitech ex110 keyboard stopped working all of a sudden
First make sure the receiver is plugged into the computer. Second make sure you have fresh batteries in the keyboard and they are installed in the correct orientation. Then try the following:
1. Press the Connect button on the receiver. The receiver's LEDs will go into a sequential flashing to indicate that the receiver is ready to accept a connection.
2. Press the Connect button on the bottom of the keyboard. The receiver's LEDs will now stop flashing sequentially. Then all the LEDs go off briefly, then they will all flash once before returning to the state it was in before the connect button was pressed.
3. Your keyboard should now be connected to the receiver.
This article should also be of help:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/
std_adp.php?p_faqid=8121
Please let me know if this works and rate my response.
Thanks.
SOURCE: Logitech cordless desktop ex110
They should have an on/off switch on the underside that you can use to switch on/off...
SOURCE: Logitech wireless mouse and keyboard
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
SOURCE: Logitech MX 5000 Wireless Laser Keyboard & Mouse Combo
HELLO, ALL YOU HAVE TO DO IS TO DOWN LOAD THE SOFT WARE THEN PLUG IN THE USB AND AFTER THAT ON YOUR RECIEVER CLICK THE CONNECT BUTTON ON THE RECIEVER TILL IT RECONIZES BOTH KEY BOARD AND MOUSE I HAVE THE LOGITECH WIRELESS SYSTEM AND I LOVE IT TILL THE BATTERIES GO OUT ON THE MOUSE OR KEY BOARD LOL THEN RESTART YOUR COMPUTER.
the new mouse is working fine but nothing happens when I press the little red button on the underside of the keyboard. The new logitech receiver is tiny and has no on off button
