I assume you mean a square base.
2.0833 litres.
If this is homework, be sure to show your work.
Be careful of the language you use. A cube is a solid.
If I understand correctly, you have a square-based right pyramid. The length of a side of the base of the pyramid is 25 cm or 2.5 decimeters (2.5 dm). The altitude (height) of the pyramid is 0.1 m or 1 dm
The formula for the volume of a right pyramid is given by
V_pyr=(1/3)(area of base)*height
V_py=(1/3)*[(2.5 dm )^2]* (1 dm)= (25/12) dm^3
Since 1 dm^3 =1 Liter
V_pyr=(25/12) L=2.083333....3 L
SOURCE: how do i perform the calculation of log (base 2)
Yes look you can't enter the base in calculators it's default 10 so use:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
so instead of log 8 base 2 input log 8 / log 2 it's easy
hope you understand :)
