Dryer not heating. Have changed thermal fuses twice, thermistor once, still blowing the thermal fuse and not heating- there are no error codes and rest of dryer is working well (tumbling etc.) just keeps blowing fuses- does the safety thermostat need changed or the whole board? Repairman charged almost $200 to change thermistor and thermal fuse and it quit working on the second load I was drying (it did heat for that first load). It is getting good air with no lint build up.
SOURCE: no heat
Is the ignitor glowing? There is a flame sesor on the burner assembly if it is open you will not get any power to the ignitor to lite the gas.
SOURCE: Maytag dryer isn't heating
You never mentioned if you checked the large klixon mounted above the heater.If it is bad you will have no heat but the dryer will run. If the thermal fuse (mounted on the right hand side of the heater chamber, 2 white wires) is bad then the dryer simply will not run. If it is good then the next thing you need to check is the control thermostat mounted on the blower housing. While down there check to see if that wheel is loose. If the control thermostat is ok then you have a bad contact inside the timer. Sometimes you can clean the contacts in the timer like cleaning points on a car.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
SOURCE: I have a May Tag dryer which blows the Thermal Fuse.
I am not 100% sure, but I think that the model that maytag had with that dryer. When I was working for my local dealer I had to change several of those, and it about 2 weeks time they blew.
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
