I started my truck it fired up for a brief second and then killed. I tried again immediatly after and all it did was crank. 15-20 minutes later tried again, and it fired right up.
SOURCE: 1999 toyota tacoma Sr5 won't start
Check for fuel pressure when starting. Fuel pumps have a check valve in them that keep fuel in the rail at the injectors. If the check valve fails, the pump has to pump fuel all of the way up to the engine. Same thing with hot no-restarts. Fuel pump.
SOURCE: 92 buick lesabre: yesterday, it would not start when it was hot.
Crank sensor. Next time it does this spray some water on it and see if it cranks. Its by the crankshaft pulley towards front of car.
SOURCE: i have a 2003 chev impala with a ignition kill
You might just have a Ignition Coil Mod or Coil Pack problem. Brendan
SOURCE: 1999 Chevy Blazer won't start in cold weather?
sounds like spider injectors there like $450 alone mine did that last winter looking at easy 700 to fix
i just had the fuel pump replaced about 2 months ago. it just happens not start like once every 2-3 weeks. then when i try 20 minutes later it starts right up.
