Question about Brother SX-4000 Typewriter
Brother SX-4000 broken Platen Knob
I have a Brother SX-4000 and the Platen Knob broke off. Is that something that can be replaced, if so how much? Thank you
Posted by J Rock on
Dick O Reilly
  • Brother Master
  • 3,594 Answers
Google smith corona dunkirk ny they will have a replacement.
DickyO
Posted on Feb 27, 2014
5 Related Answers
RadarRon
Ron Dufek
  • 398 Answers
SOURCE: installing correction tape on brother sx-4000 typewriter
If this is hard to see you can get the manual here
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF
Posted on Mar 19, 2008
Anonymous
SOURCE: I'm having a problem installing a new "correction tape"
Lost manual need to know how to reset margin
Posted on Aug 19, 2008
Anonymous
  • 183 Answers
SOURCE: brother typewriter sx 4000
make sure the ribbon and correction tape are installed correctly between the metal fingers on the far side of the printwheel and the cardholder. make sure there is no forien objects in the P/W or anything touching the petals on the P/W. turn mach. off for 10 secounds then back on or just hold down the code key and hit the Q (reset) if it still doesn't work, it will need repair or replacement.
Posted on Nov 15, 2008
Anonymous
  • 6 Answers
SOURCE: typing wrong letters on Brother SX-4000
Try hitting [CODE] + [RESET] at the same time to reset the cartridge. Make sure the cassette is installed correctly.. the "ear" on the cassette should always be on the upper right.
Posted on Apr 06, 2009
Dick O Reilly
  • 3594 Answers
SOURCE: reset margins
Above the number keys are words in green or blue the margin release, L. mar. and R. mar. are there return to the L. margin, press the alt key with the mar. rel. release them, backspace to the location for the L. mzr press alt and L. margin key, R. margin works the same way.
DickyO
Posted on Jun 19, 2009
Is there a correct side to the correction tape and will it dry out. This maybe why mine does not work. model # sx4000
The tape must be installed with the dull side toward the platen. Yes they do get old and don't work.
DickyO
Aug 25, 2011 | Brother SX-4000 Typewriter
When i type letters they come up with other letters that don't correspond with the keys I hit. I have the brother sx-4000
If you aren't in KBII or a language mode or P.S. pitch the printwheel homing pawl is probably broken. You need a tech.
DickyO
Jun 14, 2011 | Brother SX-4000 Typewriter
Problem with the line spacing on my brother sx-4000 typewriter. The spacing wheel is not moving the paper down to the next line. I've moved the lever on the right side back and forth to see if it...
If all the settings are right and it feeds with the platen knob the plastic gear on the index mitor is probably broken the part is about 25.00 plus installation.
DickyO
Jun 07, 2011 | Brother SX-4000 Typewriter
My typewriter keeps returning to the same line.
If it will space up with the platen knob the plastic gear on the feed motor is broken. The last time I replaced one the motor and gear was 35.00.
DickyO
May 02, 2011 | Brother SX-4000 Typewriter
What is being typed is not what I am typling. Im using a Brother SX-4000
If tou aren't in KBII or proportoional space the homing pawl for the printwheel is broken you need a teck.
DickyO
Jul 26, 2010 | Brother SX-4000 Typewriter
Unable to get platen roller to revolve
Most likely the plastic gear on the motor is broken. If so you'll need a tech.
DickyO
Jun 27, 2010 | Brother SX-4000 Typewriter
Feeding paper
Be sure the lower feed rolls are closed and turn the platen knob.
A userers manual is available at brother.com, click on support.
DickyO
Apr 26, 2010 | Brother SX-4000 Typewriter
Brother SX 4000 stopped printing. Ribbon is
Remove and inspect the ribbon cartrige, wind the knob and make sure that the ribbon moves and reinstall. Check that the correction tape is installed properly. Check that the ribbon plate assembly is not in the correction position. Try CODE RESET (Q key)
Dec 22, 2009 | Brother Office Equipment & Supplies
Need to Replace Paper Supporter
Try thrift stores, garage sales. No longer available from Brother.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jul 30, 2008 | Brother SX-4000 Typewriter
Brother SX-4000 Typewriter Logo
169 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
