Question about Maytag Atlantis MDG6400AW Gas Dryer
MDG9700A electric dryer won't heat - Maytag Atlantis MDG6400AW Gas Dryer
Describe your Neptune MDG9700A Gas Dryer Problem igniter clicks a couple of times then stops, burner does not light. had code of 02
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Maytag Neptune MDG9700A Gas Dryer
Everything functions but the heat.
heatman101
Aug 21, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Will not get hot
heatman101][][
Apr 25, 2011 | Maytag Neptune MDG9700A Gas Dryer
Spins, blow air but not hot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 18, 2010 | Maytag Neptune MDG9700A Gas Dryer
My dryer has not heat during cycles... How could I check for heating problems?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 15, 2010 | Maytag Neptune MDG9700A Gas Dryer
My dryer works but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 09, 2010 | Maytag Neptune MDG9700A Gas Dryer
This is a gas dryer and it runs but doesn't get hot.
heatman101
Jun 05, 2010 | Maytag Neptune MDG9700A Gas Dryer
My maytag dryer is not staying hot to dry clothes
heatman101
May 19, 2010 | Maytag Neptune MDG9700A Gas Dryer
Will not heat up
DE713 is an electric Dryer
Feb 11, 2008 | Maytag Neptune MDG9700A Gas Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
21 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
