Jumper on motherboard. Can it be used to factory reset the router when the external reset button doesn't work?
There is sort of a universal reset for routers known as 30/30/30.
The trick to this fix is to KEEP HOLDING the reset button in the ENTIRE TIME. Do not release button until ALL steps are done.
Make sure the router is plugged in and ON. Press and hold the reset button in for 30 seconds. UNPLUG from wall (keep holding button in) and wait ANOTHER 30 seconds of hold time. PLUG BACK IN and continue to hold button in ANOTHER 30 seconds. Then release.
The link below is to an article I found on Google, you probably don't need it too, but is included for further clarity.
The 30 30 30 Hard Reset Rule for Routers
Testimonial: "I have tried that in the past and I tried it again, but the only thing that happens is that the LED's flash on and then off. The router never boots. I played around with the 4 pin jumper on the board and it doesn't do much. Pins 1 & 4 shorted together seem to do the same thing as a cold boot. the LED's flash on and off then nothing. Does anyone know where I can get a tech sheet or manual for this thing? I hate to toss a board if I can get it to work again."
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button
on the back of the router for 30 seconds will reset your router to its
factory default settings. All of the settings of the router will then
be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
