SOURCE: convergence board diodes
how about looking at the output resistors... also look at the fuses feeding the stks ussally if the blow the two fuses blow
SOURCE: convergence
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link:
SOURCE: Hitachi 51UWX20B Projection TV
Hitachi part number JT23051 is Obsolete the new part number for the Deflection Convergence PWB is JT23051R its available from Hitachi for around 350.00
SOURCE: HITACHI ULTRAVISION 60" MODEL # 60SX10B COLOR NOT IN SINC
Yes replace both STKs, I always use the 392-180s they are the king of ICs ,also look for burt or open low ohm resistors you may have a few bad ones . you can go to www.electroix.com they have the parts you need 1-800-223-3205 if you need anymore help let me know.
