Question about Belkin Basic Wireless Router
Viw my password router - Belkin Basic Wireless Router
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords
Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next?
Login to Your ZyXEL Router Using the Router Password
Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: ===============
Forgot Router Password?
If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings.
What should you do?
Login to Your Router Using the Default Router Password
Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides.
Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!)
Find Your Default Router Password
Simply select your router manufacturer from the list below to display the default router passwords and usernames.
Nov 02, 2014 | Zyxel Computers & Internet
Reset password to the router and get a new one
Are you trying to reset the router password or wireless network password?
Wireless network password is different than router access password.
To change the wireless password, you will need to access the router page and change the settings.
See how to find wireless network password
To change the router access password, you can log in to router page and go to administration tab. There you will find the place to change the router password.
Jan 09, 2012 | Linksys WRT120N Wireless Router
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
Viwe cam pro pk 335mb dowmload
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 23, 2011 | A4tech Viewcam PK335 Webcam
How to connect my tp link wireless router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either...
if you were using Fariya before wi tribe or any other dialer to connect internet, you have to first remove that one.
To remove the dialer or connection you have to go to run, type ncpa.cpl there and then in new opened window remove the old connection (e.g Fariya)
Dec 04, 2010 | Linksys WRH54G Wireless Router
I forgot my password
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Oct 31, 2010 | Linksys Wireless-G WRT54G Router
Lost my password
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password.
Oct 24, 2010 | Belkin Computers & Internet
I have forgotten the password/security details of my old yahoo accounts. I wish to access them now.
Contact Yahoo and give them your information. They can email your user name and password, if you can answer your security questions.
Jul 01, 2010 | Yahoo Mail
(F5D8231-4) Wireless Router (F5D82314): need password to setup...
May 07, 2010 | Belkin (F5D8231-4) Wireless Router...
CHANGE PASSWORD/ETHERNET ROUTER/WINDOWS VISTA
to make it clear..
change password meaning you need to update your router's password?
SOLUTION: access router's interface and enter correct password information
OR
change password meaning reset your password for your router?
SOLUTION: call router provider/manufacturer ISP to have router's password reset..
Jul 17, 2008 | Alcatel Speed Touch Home Modem
Belkin Basic Wireless Router Logo
26 people viewed this question
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
