After purchasing the direct download of Movie edit Pro 14, I found that my system is not compatible. How can I install the download of Magic Movie Edit 14 in Windows 7?
You try try the compatibility wizard in Windows 7 to see if you can install Magix Move Edit Pro 14 in compatibility mode for Windows Vista.
To run the Program Compatibility troubleshooter
, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
Posted on Mar 01, 2014
SOURCE: Magix Movie Edit Pro 15 - no sound. I click on
I have the exact same problem. Every .mod file I import has no sound in MEP15 in edit mode. They play fine on my video camera. I can convert them to .mpeg and they play fine in windows media player.
Posted on Dec 15, 2009
SOURCE: Magix Movie Edit Pro 15 - in Edit mode, my movies
my music player does not used
Posted on Mar 21, 2010
SOURCE: magix edit pro 15 plus download version - the
Open the link for Magix edit pro 15 plus download version
http://www.mydigitallife.info/2009/08/12/magix-movie-edit-pro-15-silver-free-download-with-unlock-activation-code/
Download it from there
Was it helpfull ?
Waiting for your rating.
Posted on Mar 16, 2011
SOURCE: is movie edit pro 14
It should, because it worked on Windows Vista, which Windows 7 is based on. If it doesn't work, you can right-click on the desktop shortcut, and under the Compatibility tab, you can change it to Windows Vista SP2, which should let the program start.
Posted on Aug 19, 2011
SOURCE: I have problem reinstalling magix edit pro 17
Maybe a file in the usual program or configuration directory was locked by another program (e.g. antivirus scans) when you were removing the old edition of Magix Edit Pro; that would leave directories like /Programs/Magix and /Data/Programs/Magix and possibly registry entries (call up RegEdit and delete (or export and then delete) the old items pertaining to Magix or EditPro) around blocking 17 from coming in. Just rename those vestigial directories so they won't be in the install's way. Then retry and report...success?
Posted on Oct 04, 2011
Oct 21, 2013 | Magix Movie Edit Pro 14 for PC
Apr 10, 2012 | Magix MOVIE EDIT PRO 17 HD PLUS
Nov 25, 2011 | Magix Movie Edit Pro 15 for PC
Oct 02, 2011 | Magix MOVIE EDIT PRO 17 HD PLUS
Aug 19, 2011 | Magix Movie Edit Pro 14 for PC
May 06, 2011 | Magix Movie Edit Pro 14 for PC
Mar 28, 2011 | Magix Movie Edit Pro 12 Full Version for...
Mar 16, 2011 | Magix Movie Edit Pro 15 Plus Full Version...
May 02, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Dec 01, 2009 | Magix Movie Edit Pro 14 for PC
176 people viewed this question
