Question about Polaroid FLM-3732 Television
Led flatscreen TV
Picture goes Blinks off and on, is of poor quality, sound is OK.
Posted by Dennis Glenn on
1 Related Answer
circuitworld
Circuit World
  • 335 Answers
SOURCE: very poor sound quality
After installing parts on a board some tv's require that you reset some values on the tv's servicing software. This software is only available to certified techs but you can search the net to try and find it. the caps that were replaced should be of exact value in 3 criteria:
1 Voltage
2 micro farads
3 temperature
Also a note of safety:
There are HIGH VOLTAGE circuits inside your tv that could inflict serious harm even when its unplugged if approached wrong. There should be warning stickers all over the chassis of the tv informing you of the danger that your exposed too. When you take out the primary power supply discharge all high voltage capacitors to cancel the harmful charge they are holding. Especially if you just turned the tv off.
Discharging HIGH VOLTAGE capacitors:
use a high wattage resistor of about 5 to 50 ohms/V of the working voltage of the capacitor. If you don't discharge the capacitors or replace caps with inaccurate values you could easily damage other sensitive circuits.
Try resetting the tv back to manufacturers specs and see if this produces better audio quality. And when ever your working on any circuit board be sure that you are well grounded. This will prevent ESD (electro static discharge) which can harm other circuits especially logic circuits. This will cause an imbalance in circuit operation and result in a non working tv eventually.
Posted on Jan 07, 2009
I have a samsung UN60FH6003F T.V, the T.V makes a sound when you turn it on like a boot up sound but no picture. The red LED in the front blinks 6 times and then goes black.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, or the LED light stationery; the main board is faulty.
Jun 18, 2018 | Samsung Televison & Video
No picture no sound. Red led blinks once relay clicks once and repeats
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 25, 2014 | Sony KV-XF34M65 34" TV
Baird tv has no picture but sound ok. picture lights up when turning on and off but then goes out.y
Hi Anon,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Jan 07, 2014 | Vizio GV47LF Television
Picture quality poor on certain channels,get all of bbc channels ok rest loss of sound and hick ups in picture
if all channels poor quality TV problem
if just one or tow channels bad quality not tv problem....
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Flatscreen tv no picture instead of green light for power it blinks red
The led blinking is an error code from the internal processor - defining the nature/area of the TV's internal problem.
A service manual (if available) will de-cipher the code.
The tv will probably need to be repaired by a service technician.
Oct 07, 2009 | Philips Televison & Video
After about ten minutes the picture goes blank but
It sounds like the main board may have went on the TV. It should be not that costly to replace
Sep 26, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
Sony TV model KV29F3U
check high voltage rating capacitor hoirzontal output or around the the flyback transformer. if you need my [email protected]
Feb 15, 2008 | RCA F27645 27" TV
Sony KV-28CL10U TV
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 08, 2017 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Televison & Video Logo
21 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
