There are a few potential causes for why your Numatic George wet/dry vacuum is not spraying and only producing a faint buzzing sound. Here are some troubleshooting steps you can try:
Check the water level: Make sure that the water level in the tank is sufficient and not too low. If the water level is too low, it can cause the spray function to malfunction.
Check the water supply hose: Make sure that the water supply hose is properly connected and not kinked or damaged.
Check the spray nozzle: Make sure that the spray nozzle is not clogged and is able to rotate freely. If the nozzle is clogged, it can prevent the spray function from working properly.
Check the motor: If the motor is not functioning properly, it can cause the spray function to malfunction. To check the motor, you can try running the vacuum without the hose or attachments to see if it is functioning properly. If the motor is not functioning properly, it may need to be repaired or replaced.
If these troubleshooting steps do not resolve the issue, it may be necessary to take the vacuum to a professional for repair.
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed. http://hoover.com/file/604/
No the switch for the pump will work without main vacuum switched on.
Your problem could either be faulty pump switch or faulty pump,
You should be able to get spares relatively easy from any independant vacuum repair shop.
Dont try currys etc they wont have a clue what your talking about.
