Question about Xitel INport (HFLI1X1) Audio Input
Which xitel product records directly from turntable
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
0047BB69 with the LP Recorder
This is not a solution. i have just discovered that I have exactly the same problem.
Nov 06, 2013 | Xitel INport (HFLI1X1) Audio Input
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
Lost CD
heres the link where you can download the software that you it will take you directly to xitel product support
http://www.xitel.com/USA/support_inport_vista.htm
Nov 23, 2009 | Xitel INport Deluxe
Recording tracks from vynal stop recording after 1minute
2 solutions, check all hook ups and make sure they ok, 1. see if your turntable can be played thru the stereo like amp or receiver with your audio cords and record that way to cassette tape. 2. if your turntable can go thru computer using usb cord and make sure you have download your software that came with your turntable if it didn't go store and like office max or simlair buy a product called inport deluxe by xitel
Jul 26, 2009 | Numark ttUSB Turntable
Problems with Xitel INport Audio
I have Xitel plug and play and it works perfect on my PC-- do they have a driver to work on my mac. john
Apr 17, 2008 | Xitel INport (HFLI1X1) Audio Input
Xitel INport audio not coming through
Change your recording device in your control panel back to your soundcard that will allow the sound back to your computer. In order to record you had to change it to Inport.
Apr 16, 2008 | Xitel INport (HFLI1X1) Audio Input
What to use for Audio-out on Denon AVR-2807?
Hi Karmor
Use the Tape Out(rec) connections on the Denon. If that model has a rec out selector, then be sure to select phono as well. All sweet and ready to rip them files!!
regards
Graeme
Mar 15, 2008 | Denon AVR-2807 Receiver
Xitel INport (HFLI1X1) Audio Input Logo
133 people viewed this question
Top Xitel Televison & Video Experts
Marvin
Marvin
Are you a Xitel Televison and Video Expert? Answer questions, earn points and help others
